Runs fine then dies - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ToddPSD, this thread has received 4 replies and been viewed 2038 times.
post #1 of 5 (permalink) Old 04-21-2010, 04:36 AM Thread Starter
ToddPSD's Avatar
Runs fine then dies
I took my truck for a spin today and it died on me 5 times. I would be at a red light not in gear and it would just die. It would take forever to get started again but would fire up and run fine. What should I be looking for? Cam position sensor?
1993 HMC4 Hummer 100% Grade A Beef
4bt Cummins and a couple of other things.
2008 F350 CCLB 4x4 6.4L
Naked.....
ToddPSD is offline
post #2 of 5 (permalink) Old 04-21-2010, 12:52 PM
plainredtruck's Avatar
Images: 11
It's as good a place as any to start if you just want to throw parts at it.
Could be fuel pump.
Could be a few other things.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
ToddPSD (04-21-2010)
post #3 of 5 (permalink) Old 05-13-2010, 10:46 PM Thread Starter
ToddPSD's Avatar
I haven't had time to work on the truck at all but it will still die on me when I go to shift gears or stop at a light sometimes. It doesn't do it all of the time but just when its the most inconvient time possible. If I am coasting I throw it into 6th gear and pop the clutch out and it will fire right back up no problem. But if it dies while I'm stopped it will take forever to crank up again. It will not smoke while cranking or anything. It died on the way to church the other day and I just coasted in the parking lot and went inside to talk with Jesus and when I came back out it fired right up. Only to die a few blocks away.
I looked it over and there is a couple wires that is not hooked up. Anyone know what these go to or have a thought on my troubles?
Naked.....
ToddPSD is offline
post #4 of 5 (permalink) Old 05-14-2010, 12:35 AM
blageurt's Avatar
Could be the crappy tin nut on the back of the IPR which might be loose ....
95 E350 Cargo , BB shim
DP flashed 60 Tow PCM , B&M Aluminium Pan , Transgo Shift Kit , Autometer Triple Pod avec Guages , Cat sleeps with the fishes, Dana 70 FF 3:55 , Timbrens SES Kit
Stage I injectors / IDM mod coming soon
blageurt is offline
post #5 of 5 (permalink) Old 05-15-2010, 12:31 AM Thread Starter
ToddPSD's Avatar
What is the IPR?
Naked.....
ToddPSD is offline
idles fine but runs rough problem ccp 1994-2003 7.3L Power Stroke 10 11-23-2009 04:00 PM
Check engine light, runs bad, turn key off then on, runs fine? Stevie Mac 1994-2003 7.3L Power Stroke 10 09-21-2009 02:50 AM
Truck runs fine only when I add power service Horn399 2003-2007 6.0L Power Stroke 10 07-14-2009 09:32 PM
Truck Runs Then Dies 01CUMMINS24 5.9L Cummins (2003-2007.5) 5 12-03-2007 03:34 PM
runs then dies midnightcaper 1994-2003 7.3L Power Stroke 5 09-11-2006 02:36 AM
