450 to 500hp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chrisf97305, this thread has received 12 replies and been viewed 2862 times.
post #1 of 13 (permalink) Old 04-25-2010, 04:27 AM Thread Starter
450 to 500hp
Last dyno run I put down a 380hp run. I have in place the fuel system, head studs, valve springs and pushrods, and hpop system. I know what turbo I want and will have it for next pulling season. The question I have now is how big of a injector do I need for the 450 to 500hp level. I drive this truck as a daily driver, Truck pull, 1/4 mile drag race and sand race with it.
What is the rule of thump when figuring injector size?
Thanks
chrisf97305 is offline
post #2 of 13 (permalink) Old 04-26-2010, 04:48 AM
easy money's Avatar
I'm at 425 hp with a set of hybrids and open exhaust, diy intake and IDM mod, this is going by the calculators here at TDG. my hybrids are 238cc.
1995 f250 2wd PSD, auto, DIY intake, DIY exhaust, PHP tuned 40hp tune , Hybrids injectors 238cc..... 13.618 in the 1/4 at 6000lbs.
1995 GMC 3500HD dump truck 6.5 turbo(lol) DIY intake and exhaust.
2008 GMC 2500 hd stock for now.EFI LIVE installed!!!!!
easy money is offline
post #3 of 13 (permalink) Old 04-26-2010, 04:55 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
i would say some 250/100s would be more then enough to make over 500 with the right suporting mods.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #4 of 13 (permalink) Old 04-27-2010, 02:16 AM Thread Starter
can you enplane what you mean by 250/100's
post #5 of 13 (permalink) Old 04-27-2010, 04:11 AM
joebob3093's Avatar
250cc 100% nozzles.
post #6 of 13 (permalink) Old 04-27-2010, 04:38 AM
lee boy's Avatar
You should be able to get more with a tuner. I dynoed my truck two weeks ago an it got 425 hp with only tuner, straight pipe, intake elbow and cold air intake and it still wanted to go up more it wasn't going all the way yet, but I didn't want to push it even more. The graph was still going up when we would release the gas pedal. Its a 05 6.0
R.I.P My First Diesel Hit by lady
running red light:Just like the avatar pic but mine was red(
4/4/06-3/28/08:: Totaled frame twist
RED 2006 Ford F250 powerstroke Lariat crew cab sb
7inch lift
4 inch straight pipe, no cat or muffler to 6inch tip
Chrome accufab intake elbow
22inch kmc with 37 inch kumho tires
Amp powersteps
Zoodad mod
HOPEFULLY SOON: Injectors, headstuds,sct:
Dads truck: 1997 F-250 4x4Black crew cab short bed 7.5L 460 engine:
6 inch lift on 35's
Fox shocks
K&N Fipk filter kit
BBK throtle body
Helix power spacer, 50 series Flow Masters:3inch dual exhaust piping to 5inch tips
My New Truck2005 F-250 4x4 powerstroke Crew cab short bed Charcoal gray metalic all stock , but not for long
Zoodad mod
4inch Turbo Back straight pipe to 5 inch Chrome Tip , exiting in front of rear right tire
Polished intake elbow
Sct Livewire
S&B Cold Air Intake
3 gauge A Pillar with Phantom II"s / PYRO/ BOOST/TRANS
Viper Alarm Remote Start/ Turbo Timer/ Window Module setup
5% tint all around
Dynoed at 425Hp 850 torque
03 Turbo VEEEEERy LOud
Cobra Cb Radio
The perfect Sleeper Looking truck/ Looks completely stock from the outside except for the turbo back exhaust, and when I get challenge they quickly find out it's not stock haha
lee boy is offline
post #7 of 13 (permalink) Old 04-27-2010, 04:43 AM Thread Starter
That's the difference between the 6.0 and my obs 7.3. First dyno pull was only 155hp at the rear wheels. I know that I need bigger injectors but how big. I don't want to go to big, don't want the heat. I use this truck hard, truck pull, drag racing and started last year at sand drags. So I am after usable horse power.
post #8 of 13 (permalink) Old 04-27-2010, 05:56 AM
joebob3093's Avatar
it all depends on your supporting mods, but i would go with some hybrids either 238s or 250s. the nozzle size will determine the amount of power, smoke and heat they will generate.
post #9 of 13 (permalink) Old 04-27-2010, 01:25 PM
Banned
This last weekend when I dynoed my 99 7.3 I put down a 516 HP and 1121 TQ with 238cc Hybrids with 80% over stock nozzles from Nate at Unlimited a 38r BB turbo with a 1.00 housing, a custom chip from Matt at Gearhead and some other supporting mods. This is the 2nd time I have been on a dyno and put down over 500hp it is a proven setup.
This is also my daily driver and I tow gooseneck with it and everything with no issue
strokin_stroker is offline
post #10 of 13 (permalink) Old 04-28-2010, 03:40 AM
easy money's Avatar
99 crew cab 250 350?
How to reach 500hp 02 d-max. lapplander Duramax 2001-2004 (LB7) 7 04-24-2008 03:03 AM
Whos ****hing 500HP Macktruckdriver 1994-2003 7.3L Power Stroke 19 03-11-2008 03:41 AM
A route to 500hp JohnNolen 1994-2003 7.3L Power Stroke 23 01-09-2008 02:58 AM
clutch (500hp+) Okie2500 Supporting Vendors Forum 2 07-12-2007 03:22 AM
500hp 3.0L Mercedes! The Eagle Dyno Board 0 05-23-2006 07:45 AM
