Truck wont start unless plugged in - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brodiesau, this thread has received 9 replies and been viewed 5980 times.
post #1 of 10 (permalink) Old 04-25-2010, 11:00 PM Thread Starter
I tested the glow plugs resistance and they're all good. Glow plug relay is good
truck wont start unless its plugged in for about an hour! any ideas? thanks!
brodiesau is offline
The Following User Says Thank You to brodiesau For this addition to TDG:
wreckit59 (07-06-2010)
post #2 of 10 (permalink) Old 04-26-2010, 12:53 AM
bpogue's Avatar
How did you test the GPR? What has the outside temperature been lately? If you run it for a while, how long does it have to sit before it is hard to start? Once started, does it run smooth immediately or does it seem to lope for a while?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 10 (permalink) Old 04-26-2010, 01:36 AM Thread Starter
hey thanx 4 the quick reply. I tested the relay by measuring the voltage, and i got 12 volts when the key was turned on. Its been like 20+ degrees celcius, nice and warm and usually after it sits out all night without being plugged in she wont go in the mornin! If shes plugged in she normally runs pretty good, maybe a little sluggish from time to time.
post #4 of 10 (permalink) Old 05-01-2010, 05:10 PM
There's your problem.
Send a message via AIM to Dutch
how many miles are on the truck?
Dutch is offline
post #5 of 10 (permalink) Old 05-01-2010, 07:00 PM
SmokeCloud's Avatar
Check for bad grounds.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #6 of 10 (permalink) Old 05-02-2010, 03:30 PM Thread Starter
299k ICP sensor is all oily where the electric connector plugs together, so bad I think but does this have something to do with block heater needing to be plugged in?
post #7 of 10 (permalink) Old 05-02-2010, 04:54 PM
there is a problem with the international trucks, the injectors solenoids are worn and when there cold they cant complete the gap. when its warm its hot enough everything expands and we can complete the gap and fire them off.
Dutch is offline
post #8 of 10 (permalink) Old 05-02-2010, 05:20 PM Thread Starter
so it may be injector solenoids? is there eight of them? I've never heard of this. thanx 4 the help
post #9 of 10 (permalink) Old 05-02-2010, 08:47 PM
the spool valves get sticky from sludge. you can try running a coupld qts of trans fluid in the oil that fixes half of them but sometimes they need to be replaced.
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline
post #10 of 10 (permalink) Old 05-02-2010, 09:45 PM Thread Starter
what the **** is a spool valve?
**** ford time 4 a duramax
HELP! truck wont start SSpeeDEMONSS 2003-2007 6.0L Power Stroke 29 04-01-2008 01:30 AM
HELP! Truck wont start!! BigWhite250 1994-2003 7.3L Power Stroke 5 04-09-2006 04:54 AM
