OD lockout for 97... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 4 replies and been viewed 1094 times.
post #1 of 5 (permalink) Old 04-26-2010, 01:20 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
Is there a way to wire something up to keep the trans from shifting into OD while pulling??? Even by turning it off on the shifter it will still shift into OD while sled pulling. Thanks.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 5 (permalink) Old 04-27-2010, 11:57 PM
trackspeeder's Avatar
Check the wiring to the OD off button. When you depress that button the trans cannot go into 4th. Unless the wiring or the button is bad.
01 F250 4X4, 7.3.
90 F350 4X4, 7.3
85 F250 4X2 6.9
08 Arctic Cat 700 4X4, Diesel
Easy button for photos
trackspeeder is offline
post #3 of 5 (permalink) Old 05-02-2010, 07:21 PM
are you positive its going into OD and not just 3rd gear lockup.
stevemic is offline
post #4 of 5 (permalink) Old 05-02-2010, 08:25 PM
converter lock up?
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline
post #5 of 5 (permalink) Old 05-02-2010, 09:51 PM
Originally Posted by fordboyyfm View Post
converter lock up?
ya.
stevemic is offline
is this the right lockout? 6L strokin General Ford Truck and Excursion 6 03-10-2010 03:33 AM
OD Lockout? dgrindst 2008-2010 6.4L Power Stroke 2 09-28-2009 02:58 PM
OD lockout switch? can u do it? wildchild97 5.9L Cummins (2003-2007.5) 0 08-13-2007 05:18 AM
O/D lockout? noreaster General GM Truck Forum 4 05-09-2006 02:15 AM
