Question - Return Line on Fuel Bowl - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Seafordguy, this thread has received 2 replies and been viewed 1543 times.
post #1 of 3 (permalink) Old 04-29-2010, 12:38 AM Thread Starter
When reinstalling my HPOP I made a true ******* move and sheered off the male side of the fitting shown in this picture.
Any suggestions?
I was going to try to get the fitting, and put it back on with the torx screws, then cut off the return line (because the sheered off section is in the flare fitting) and then just use a short piece of hose with hose clamps between the two, assuming it isn't under tremendous pressure.
Any thoughts??
I'm not suggesting it is any better than stock, but what about just deleting the return???
Anyone have one of these fittings they want to get rid of?
Seafordguy is offline
post #2 of 3 (permalink) Old 04-29-2010, 01:02 AM Thread Starter
Pic....
Name:	Fuel Return.jpg
post #3 of 3 (permalink) Old 04-29-2010, 01:18 AM Thread Starter
Nevermind - Just found this.
http://www.guzzle7pt3.com/fbowl.php
Looks like they are a weak spot and aren't under heavy pressure.
fuel return line john_k_45 5.9L Cummins 12 Valve (1994-1998.5) 7 09-23-2009 12:24 AM
fuel bowl feed line fitting strokin6L 2003-2007 6.0L Power Stroke 15 03-20-2009 07:45 AM
fuel return line stillcrazyinlaw 5.9L Cummins 12 Valve (1994-1998.5) 1 02-25-2008 09:48 PM
fuel return line? f_stahl 1994-2003 7.3L Power Stroke 3 02-08-2007 01:28 AM
return line on fuel housing doob51 5.9L Cummins 12 Valve (1994-1998.5) 1 01-14-2007 08:07 AM
