99.5 7.3 oil crossover line and Swamps Injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by INT_MAN, this thread has received 2 replies and been viewed 3782 times.
post #1 of 3 (permalink) Old 04-29-2010, 05:51 AM Thread Starter
This is my first powerstroke, and before I had a cummins so bear with me.
The truck presently is all stock sans muffler delete
been researching high pressure oil crossover lines, swamps injectors and such for my 99.5 super duty, and here is my thoughts, any insight would be appreciated.
swamps 160cc single shots, oil crossover line, afe intake , and mbrp '4 inch exhaust.
this setup is to eliminate the #8 long lead , and get a fresh set of injectors(they have 200k on them and #8 has failed).
the crossover line is to make it idle better, and hopefully make number 8 last longer in addition to lowering noise.
what kind of power will I be looking at with this setup, and will this shred my rebuilt auto ? thanks guys
Late 99 F250 powerstroke 4x4, PMR motor all stock except for muffler/cat delete 315/75/16 tires SOLD
1990 BMY M923 5 Ton 6X6 military truck with 8.3 cummins, allison mt643c, central tire inflation system, 49 inch goodyears (1400x20)
1999 international s/a tractor 4900, air brakes, dt466ht fuller 6 speed air brakes 11r22.5
INT_MAN is offline
post #2 of 3 (permalink) Old 04-29-2010, 04:13 PM
4cstr's Avatar
Images: 35
Personally...don't spend the money on the cross over line. It quiets the idle slightly...but with the singles you are planning on dropping in...you won't notice it. If you want to help the injectors last as long as possible...instead look at getting a regulated fuel return kit. Dennis at ITP carries a great kit for the money.
And you will need tuning to make those singles work in the truck.
Other than that...if you behave your tranny should be ok. I would maybe look into a new valve body perhaps to aid in quicker shifts and avoid the slippage.
~Dave~
4cstr is offline
post #3 of 3 (permalink) Old 04-29-2010, 08:11 PM
Cratos's Avatar
i am happy with my swamps injectors and tunes
2012 f-240 lbsc 4x4
Cratos is offline
6.0L Fuel Crossover Line Kit dfuser Supporting Vendors Forum 0 10-11-2009 08:45 PM
Fuel crossover line 04' powerstrokin 2003-2007 6.0L Power Stroke 21 01-01-2009 09:37 PM
Crossover line crock Whats Been Sold 2 01-02-2008 02:10 AM
crossover line imported_diesel71 2003-2007 6.0L Power Stroke 8 12-21-2007 12:59 AM
crossover line cleared-up imported_diesel71 2003-2007 6.0L Power Stroke 10 02-28-2007 01:39 AM
