99.5 rear end ID for limited slip - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by INT_MAN, this thread has received 5 replies and been viewed 1592 times.
post #1 of 6 (permalink) Old 04-29-2010, 06:52 AM Thread Starter
on my 99.5 f250sd, the axle code is a little different than the 8.8 rears, the codes are more difficult to decipher. what tells me whether it is an open diff or limited slip?
Late 99 F250 powerstroke 4x4, PMR motor all stock except for muffler/cat delete 315/75/16 tires SOLD
1990 BMY M923 5 Ton 6X6 military truck with 8.3 cummins, allison mt643c, central tire inflation system, 49 inch goodyears (1400x20)
1999 international s/a tractor 4900, air brakes, dt466ht fuller 6 speed air brakes 11r22.5
INT_MAN is offline
post #2 of 6 (permalink) Old 04-30-2010, 11:19 AM
brendonv's Avatar
Try this.
https://www.thedieselgarage.com/forum...ad.php?t=83514
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
The Following User Says Thank You to brendonv For this addition to TDG:
INT_MAN (05-01-2010)
post #3 of 6 (permalink) Old 04-30-2010, 05:14 PM
Mod Friendly Title
Zaairman's Avatar
The tag on the rear end will say "3L73" or something like that.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #4 of 6 (permalink) Old 05-01-2010, 08:35 AM Thread Starter
no, actually it wont. mustangs and explorers do, but this tag has nothing like that. the code is c1, which is 3.73 limited slip. apparently the axle manufacturer uses more complicated codes than ford does.
INT_MAN is offline
post #5 of 6 (permalink) Old 05-01-2010, 01:09 PM
4cstr's Avatar
Images: 35
I have a tag on my early 99 that does say L373 or something to that effect.
I believe the door tag says something simple like C1 to indicate axle code though.
~Dave~
4cstr is offline
post #6 of 6 (permalink) Old 05-01-2010, 04:45 PM
Mod Friendly Title
Zaairman's Avatar
Want me to take a picture of the tag on my rear axle that says 3L73???
The C1 code you're talking about is on the door jam sticker, not the rear axle. And the Ford codes are very easy to decipher. If there is a letter in the code, then it has a LS. For example, my F-150 had 3.55 gears with a limited slip. It's code was H9. If it didn't have limited slip, it would have been 19. If you would have spent 2 minutes of Googling "Ford axle codes" you would have found all of this out.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
rear limited slip rebuild. buffalobob 1994-2003 7.3L Power Stroke 5 05-22-2009 06:35 PM
limited slip rear end powerstroke7.3 1994-2003 7.3L Power Stroke 8 10-16-2007 08:38 PM
rear limited slip big hunter 1994-2003 7.3L Power Stroke 1 12-17-2006 01:31 AM
Rear Limited Slip problems $trokin60 2003-2007 6.0L Power Stroke 7 07-12-2006 03:59 PM
