Aluminum wheels - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fedman, this thread has received 2 replies and been viewed 1529 times.
post #1 of 3 (permalink) Old 05-12-2010, 01:02 PM Thread Starter
Aluminum wheels
So what is the best way to clean light corrosion from aluminum wheels that is not very deep? Thanks in advance for any help.
08' F350 Lariat DRW
fedman is offline
post #2 of 3 (permalink) Old 05-12-2010, 02:17 PM
My wheels are polished aluminum. I bought them while still living in SC. Moved to Colorado shortly afterwards, and found out that the mag-chloride the state uses on the roads eats the finish off polished aluminum. Not a single off the shelf cleaner or polish could get them looking right.
Another guy showed me some acid wheel cleaner that he uses on his wheels. He sprayed a test area and wiped it clean. It took all the corrosion out of the wheel. All I had to do was slap on some polish, and it looked brand new again.
So that's what I do after every winter season. Acid clean and polish.
The acid cleaner is not available off the shelf. Here is a link to a company that sells the stuff for fairly cheap: http://www.k-chemicals.com/pages/autotire.html
It's the first product on the page, called Brite Aluminum Cleaner. Remember, this stuff is hydrofluoric acid, and you MUST be very careful when using it. Wear thick rubber gloves at all times when handling it. Hydrofluoric acid burns are extremely painful, as it seeps into the skin down to the bones, attacking the calcium in the bones.
The way I use it is to wash the truck and wheels. After it's dry, use a spray bottle and spray some acid all over the wheel. Use a damp rag (while wearing gloves, don't forget) wipe down the wheels using a light scrubbing motion. For heavy buildup or corrosion, repeat the process. You'll start to see the crud coming off, and the aluminum will have a slight whitish tint to it. Make sure you use a sprayer that sprays nice and evenly (in a mist, not a stream), and don't let the acid sit too long. Spray, count to 10, and start wiping. After the wheel is cleaned with acid, wash it again with soap and water to remove the acid. Let dry, then apply wheel polish and it should look good as new.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
fedman (05-13-2010)
post #3 of 3 (permalink) Old 05-13-2010, 04:17 AM
Mod Friendly Title
Zaairman's Avatar
http://www.f150online.com/forums/car...ew-wheels.html
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
The Following User Says Thank You to Zaairman For this addition to TDG:
fedman (05-15-2010)
Polishing Aluminum Wheels. CFRO The Detailing, Paint & Bodyshop 9 02-09-2009 11:35 PM
Aluminum Wheels fordt Towing and Hauling 2 03-20-2006 02:30 PM
Two Aluminum 16" Wheels... steved Whats Been Sold 0 03-08-2006 02:24 PM
Two aluminum wheels 16x? with 8x6.5 pattern... steved Whats Been Sold 5 02-21-2006 07:32 PM
aluminum vs steel wheels dondiesel444 Medium and Heavy Duty 17 10-16-2005 05:27 PM
