burning oil= rough running - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by crash6882, this thread has received 3 replies and been viewed 1230 times.
post #1 of 4 (permalink) Old 05-12-2010, 10:26 PM Thread Starter
well my fathers 2002 F250 died today, he said that it started studering and then died. we had it towed to a local AAA garage. the mechanic said that the injectors on the powerstrokes work on oil pressure. they checked the oil and it was very low. they added 5 quarts and started it up. It ran fine. The mechanic drove it out front, I noticed it was pushing bluish white smoke out the exhaust. when he got it out front it was still running good, then it started studering again. he shut it off and checked the oil and it was a little lower. This garage doesn't have the tools to work on diesels so they said that we had to take it to a ford garage. I went to go park it and it barely ran. now for my question. could it be possible that a seal in the turbo let go causing it to burn the oil, and hence dropping oil pressure going to injectors causing it to run rough and dieing?? if not any suggestions on what else it could be other than turbo and or rings??
crash6882 is offline
post #2 of 4 (permalink) Old 05-13-2010, 03:24 AM
if it use that much oil I would say injectors o-ring. there about $100 for all 8 o-rings I think
never run the engine with low oil like that all the injectors run off the oil
cong is offline
post #3 of 4 (permalink) Old 05-13-2010, 03:34 AM
JimTJr's Avatar
Images: 9
Supposedly they will stop working and the engine will die, before it's low enough to damage anything... is there oil in the exhaust? (Does he have a muffler, or is it open exhaust? I would pull the Down pipe clamp off, it there is a ton of oil there, the turbo is shot.... if the down pipe is dry,, then it's likely the injector "O" rings. But if the truck "Ran fine" when it was full of oil, I would doubt that myself.....
2011 F-350 Lariat 6.7L CC, LB, SRW. White Platinum Metalic Tri Coat. Retired UAW from GM, 30.8 yrs.
Proud member of the Mo. Air National Guard since 1988, 4yrs USMC before that. Now a full time technician with the guard.
JimTJr is offline
post #4 of 4 (permalink) Old 05-25-2010, 04:10 AM
Check your fuel bowl if your fuel is black definatley injector orings 18 each set at the stealership not hard to replace
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline
running rough droolinforparts 2003-2007 6.0L Power Stroke 27 08-29-2009 02:52 PM
rough running Dieseldemon61 5.9L Cummins 12 Valve (1994-1998.5) 5 03-09-2009 01:51 AM
running rough droolinforparts 2003-2007 6.0L Power Stroke 4 04-01-2008 02:21 AM
Running Rough Smokin7.3 1994-2003 7.3L Power Stroke 0 01-18-2007 11:17 PM
12 v running rough Whitemare 5.9L Cummins 12 Valve (1994-1998.5) 5 09-24-2005 03:10 AM
