2000 7.3 won't start - starter sparks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tm0231009, this thread has received 2 replies and been viewed 1780 times.
post #1 of 3 (permalink) Old 05-14-2010, 03:56 PM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
My brothers 2000 7.3 auto 4x4 reg cab touch over 100,000 miles with new batteries that are charged will not start. He drove it school one day, drove it back home and everything was good and normal. But the next morning when he woke up to go to school it wouldn't start. All it does when you turn the key to start is hear a click (sounds like the batteries are just dead but they aren't). Almost everytime the starter gets bumped another guy can see a few sparks coming from the the starter. I have looked and felt and none of the wires on the starter are touching each other. I have taken the starter off, had it tested and passed 4 times. Taken the hot wire harness off both batteries and the starter and looked it over and everything seems to be fine. The only thing I haven't done is take a voltmeter and gone over the whole system. There is obviously power getting to the starter or else it wouldn't be sparking right? If it would quit raining here I would go and check voltage. I was going to check voltage at the batteries with and without a load and voltage at the starter when power was sent to it. Is there anything else I need to go over to find the problem and has anyone else ever experienced this before with other trucks? Thanks ahead of time.
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #2 of 3 (permalink) Old 05-16-2010, 07:04 PM
pontiacross's Avatar
sounds like a bad connection somewhere. have some one lay undernieth the truck while you try to start it and see where the sparks are comming from.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 3 (permalink) Old 05-19-2010, 09:42 AM
DRACOMIKEF250's Avatar
i had that happen on my 96 and bought a heavy duty db starter and it does not do that any more
1996 Ford F250 SCLB 4X4 7.3L
1998 Dodge 3500 dually
DRACOMIKEF250 is offline
Sparks club ! S-D Diesel Perf The Parking Lot 13 02-28-2009 09:08 AM
Starter stil sticking no start. circle5 1994-2003 7.3L Power Stroke 5 03-18-2008 06:41 PM
New starter still won't start Powerstroker250 1994-2003 7.3L Power Stroke 2 08-08-2007 04:56 PM
1972 Ford 2000 diesel hard to start fastback4 Utility & Farm Tractors 3 11-14-2006 04:41 PM
