7.3 power improvement? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TonyG, this thread has received 19 replies and been viewed 2768 times.
post #1 of 20 (permalink) Old 05-15-2010, 02:44 PM Thread Starter
I think the 7.3 we have is rated at 250HP. I have know idea what the torque numbers are. I have two questions.
1-would upgrading it to 350 be a detriment to the drive line?
2-how would one achieve this increase.
Of course, maybe I should concern myself with torque improvements. This is a towing application after all.
TonyG is offline
post #2 of 20 (permalink) Old 05-16-2010, 03:55 AM
easy money's Avatar
....upgrading the power will hurt the transmission..... quicker if its a heavy truck like crew cab, extended cab, 4x4 ....but 350hp wont hurt the transmission in a regular cab 2wd.....unless you are around every stop light.
1995 f250 2wd PSD, auto, DIY intake, DIY exhaust, PHP tuned 40hp tune , Hybrids injectors 238cc..... 13.618 in the 1/4 at 6000lbs.
1995 GMC 3500HD dump truck 6.5 turbo(lol) DIY intake and exhaust.
2008 GMC 2500 hd stock for now.EFI LIVE installed!!!!!
easy money is offline
post #3 of 20 (permalink) Old 05-16-2010, 12:02 PM Thread Starter
Easy,
this is a f550 4x4 with a 12' landscaper body w/automatic, must weigh 8500-9000lbs...not sure.
It will have to pull skid/trailer combo of 12,500, or a chipper at 5,700lb.
It's hilly here, and I was looking for a boost just for the hills.
TonyG is offline
post #4 of 20 (permalink) Old 05-16-2010, 06:50 PM
pontiacross's Avatar
what year is your truck? the upgrades to make that powwr will be differamnt depending on the year. i am assuming its a 2000-2003
if so a custom chip, exhaust, diy intake and a gtp38r turbo would probably get you close to that 350 mark but not quite there. add a set of stage one single shot injectors and it would be a mean towing machine
as for the tranny I really dont know I'm a stick guy, but hopefully some one else will chime in on that
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 20 (permalink) Old 05-16-2010, 09:41 PM Thread Starter
pontiac,
correct, it's a 2003.
TonyG is offline
post #6 of 20 (permalink) Old 05-17-2010, 11:53 PM
If you are stil using the stock size tires I would only upgrade the tranny fluid cooler. Replace it with one from and 05-06 superduty. I would also recommend getting a Banks TransCommand to firm up your tranny or a programmer that has tranny adjustment capabilities. I am running 37s on my truck and tow a 28 foot toy box with quads and bikes in it through the mountains and I have never had a problem with the tranny.
7.3L Digger is offline
post #7 of 20 (permalink) Old 05-18-2010, 03:00 AM Thread Starter
Digger,
there the stock 19's.
TonyG is offline
post #8 of 20 (permalink) Old 05-18-2010, 03:16 AM
plainredtruck's Avatar
Images: 11
You can spend a ton of cash making it go a wee bit faster and maybe, just maybe making it a tad more fuel efficient.
open exhaust, open intake, custom efficiency tune, gauges, valve body (until the tranny decides to go for good, which it will with any power adders, and likely in short order).
Unless you're prepared to spend a lot of coin on this truck, do the things listed above and save your pennies for a built transmission.
Adding power to a 9,500 lb truck as a daily driver is a crapshoot, at best.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
easy money (05-18-2010)
post #9 of 20 (permalink) Old 05-18-2010, 05:29 AM
easy money's Avatar
prt
post #10 of 20 (permalink) Old 05-18-2010, 08:09 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
if it was me i would open up the exhaust and intake. get a chip from a good tuner like, swamps, beans, gearhead. then a good torque converter and BTS or JWs valve body. then you will need a set of stage 1s and maybe a turbo.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
FORD SUPER DUTY 6.7L POWER STROKE DIESEL - Power Rating Discussion & Poll Scorpion6.7L 2011+ 6.7L Power Stroke Diesel 7 11-03-2009 03:38 PM
Improvement of Fuel Mileage kj087995 2003-2007 6.0L Power Stroke 27 09-17-2009 05:00 AM
Converting from non power to power seating. boosted_blazer General Ford Truck and Excursion 0 02-17-2009 03:09 PM
How much additional power by turning up the full power screw? colofred 5.9L Cummins (Pre 1994) 11 04-05-2007 10:26 PM
Speed Improvement killerbee Site Information 0 10-07-2006 02:27 PM
