Clutch replacement? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Maverick26, this thread has received 8 replies and been viewed 1457 times.
post #1 of 9 (permalink) Old 05-20-2010, 06:16 PM Thread Starter
Clutch replacement?
Hey I searched around and could not find much on the way of tech so I thought I would ask. Does anyone have any good pics or tips on droping the 5 speed out of a 1995 f350 to change the clutch. I got a new SBC with the SMF. Any helpful tips on doing this in a garage with no lift... its just me and my dad and we have not done a big truck like this before, just jeeps. Thanks.
Maverick26 is offline
post #2 of 9 (permalink) Old 05-21-2010, 03:17 AM
gr8whitectd's Avatar
zf 5
take t case off unless you rent a big trans jack
remove 8 shifter bolts
Use long extension with wobble head socket for top two bellhousing bolts
do not disconnect slave cylinder just tie up out of the way
o ya wash first then wash again
have fun
Logan
95 cclb 7.3
gr8whitectd is offline
post #3 of 9 (permalink) Old 05-21-2010, 12:18 PM
97_redstroke's Avatar
where did you purchase the clutch from and what kind of price where you able to find it for if you don't mind me asking? I am gonna need to order one as well in the next week or so as my throw out bearing is giving up on me.
'97 F-250 HD ext. cab shortbox, 5" mitre cut stacks, edge evolution programmer, DIY intake.
97_redstroke is offline
post #4 of 9 (permalink) Old 05-22-2010, 03:01 AM
brendonv's Avatar
I'm curious too. I got a quote with a single mass fly wheel and clutch for $1200 installed. I'm not fond on the idea of wrestling the tranny and t-case in my driveway since the truck won't fit in the garage.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #5 of 9 (permalink) Old 05-24-2010, 03:45 PM Thread Starter
Well I gave up on the idea of doing it myself too.. I got all the parts from Dynomite Diesle in Monroe, Wa. Thats who I buy from. It was $540 I think for the parts.
post #6 of 9 (permalink) Old 05-24-2010, 05:25 PM
That's a good price on the parts, I ended up giving 550.00 for mine shipped and I will probably have another few hundred in the install since I am not gonna tackle the job by myself.
post #7 of 9 (permalink) Old 05-25-2010, 10:35 PM
Don't be afraid to tackle this job on your own. I did my 99 speed with a friend in the garage with two small floor jacks. If you have a trans jack and a manual it really isn't that bad.
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
The Following User Says Thank You to calebgriffin31 For this addition to TDG:
97_redstroke (05-26-2010)
post #8 of 9 (permalink) Old 05-27-2010, 12:44 PM
yes i would say the same. i have a 95 with a 5 speed and i did it by my self with a trans jack and a floor jack i had it out and back in, in one evening! i have pulled my jeep auto trans plenty of times and it is not any harder.
1995nicholas is offline
post #9 of 9 (permalink) Old 05-27-2010, 02:48 PM
Yeah, I took the advice and with the help of a friend who is very knowledgeable on the ford zf-5 we swapped the clutch out last night and the only thing we have left is to button up the shifter and the cover plate and make sure everything is working as it should. I am also replacing the rear diff cover and fluid as the original one is starting to rust and seep oil so we r doing that as well.
Clutch replacement problem 3126cat Medium and Heavy Duty 2 05-06-2009 12:32 AM
tips on clutch replacement Jawbone 5.9L Cummins 12 Valve (1994-1998.5) 11 03-26-2009 04:02 AM
LLY Fan Clutch Replacement ripmf666 GM Spec Info 0 12-28-2008 01:25 PM
Clutch Replacement hhrecovery General Ford Truck and Excursion 2 05-19-2006 01:57 PM
Clutch replacement hhrecovery 2003-2007 6.0L Power Stroke 0 08-12-2005 04:40 PM
