gauge power switch source? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 4 replies and been viewed 1460 times.
post #1 of 5 (permalink) Old 05-23-2010, 01:44 AM Thread Starter
balz out's Avatar
where are you guys tapping into to get a switch source for gauges?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 5 (permalink) Old 05-23-2010, 04:16 AM
F350-6's Avatar
There's a customer access wire taped up to the wires leading to the OBDII port that is a switched power source. Don't remember the fuse rating on it, but you should be able to find the fuse location in your owners manual.
It's hard to find, but grab a flash light and start looking. It's got a heat shrink type stuff covering the end of the wire.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #3 of 5 (permalink) Old 05-23-2010, 04:51 AM
7.3 addict
i tapped into the headlight sw.
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #4 of 5 (permalink) Old 05-23-2010, 04:01 PM Thread Starter
balz out's Avatar
what color was the wire you tapped in to on the head light switch. thats what i wanted to do but was iffy on wires haha
balz out is offline
post #5 of 5 (permalink) Old 05-23-2010, 05:32 PM
take a look at this. it may be helpful.
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
tholt846 is offline
Diesel Power Source Twins ???? BUCK2 5.9L Cummins 12 Valve (1994-1998.5) 13 12-09-2009 03:47 PM
Keyed Power Source dieslpower97 1994-2003 7.3L Power Stroke 5 04-04-2008 01:43 AM
New F5 Gauge Switch SeeYa Supporting Vendors Forum 6 12-08-2007 01:51 AM
Finding A Switch 12 volt source.. Help Please BlackSuperStroker33 2003-2007 6.0L Power Stroke 3 08-27-2005 07:09 PM
Switch 12V Source BlackSuperStroker33 2003-2007 6.0L Power Stroke 1 08-27-2005 08:13 AM
