hpop leakdown - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker99, this thread has received 4 replies and been viewed 2051 times.
post #1 of 5 (permalink) Old 05-25-2010, 04:16 AM Thread Starter
hpop leakdown
ok so Ive replaced injector orings hp oil line seals what else could cause my hpop leak down
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline
post #2 of 5 (permalink) Old 05-25-2010, 06:16 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
IPR?
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #3 of 5 (permalink) Old 06-02-2010, 06:49 PM
Super Moderator
John_G's Avatar
The HPOP can't really leak down.
What problem or symptoms are you seeing?
I vote for LIBERTY!
John_G is offline
post #4 of 5 (permalink) Old 06-02-2010, 07:23 PM Thread Starter
lopey idle at start up after sitting for 4 or more hours lack of power when first starting no acelleration until the oil pressure comes up is what it feels like the system has to bleed out the air
post #5 of 5 (permalink) Old 06-02-2010, 08:29 PM
Super Moderator
John_G's Avatar
Lopey idle and lack of throttle response COLD only are possibally related to the HPOP reservoir leaking down but more often than not that will present as long crank-to-start and not a lope.
Your symptoms are consistant with injector armature wear, extended oil change intevals (maybe previous owner etc), or overly thick oil for the operating temps. Given the temperatures in most of the country, I fail to see how it could be the wrong oil. That leaves us with a sticking IPR valve, biased ICP sensor, wrong oil or injector wear.
Without looking at the ECM data stream while the problem is occuring, it's a crap shoot. But, I would replacethe ICP sensor just for fun and change the oil using a KNOWN good quality 15W-40 diesel oil (API CF or later).
I vote for LIBERTY!
John_G is offline
The Following User Says Thank You to John_G For this addition to TDG:
Stroker99 (06-03-2010)
ICP or HPOP? the blue beast 2003-2007 6.0L Power Stroke 7 01-26-2009 01:33 AM
Hpop 4cstr 1994-2003 7.3L Power Stroke 11 01-25-2009 08:07 PM
17* Hpop blk99 1994-2003 7.3L Power Stroke 16 10-03-2007 02:22 AM
hpop chosen1 1994-2003 7.3L Power Stroke 8 04-10-2007 01:40 PM
01 hpop on obs longerthnu2 General Ford Truck and Excursion 0 03-23-2007 08:18 AM
