Can I pull my oil pan without pulling me engine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 22 replies and been viewed 3337 times.
post #1 of 23 (permalink) Old 05-26-2010, 06:23 PM Thread Starter
The oil pan on my 1995 7.3 is right smack in the way of some holes I have to drill. Every time I have tried to drop an oil pan in a Ford in the past it did not go well. I always ended up having to pull the engine. I am pretty sure I already know the answer but I was holding out for some hope. I was hoping maybe a few of you found a trick to dropping the pan without yanking the engine. Oh, and loosening the engine mounts and lifting it up will not be an option either. There is just not room for that.
post #2 of 23 (permalink) Old 05-26-2010, 06:29 PM
michael8840's Avatar
nope,engine has to come out
1996 7.3L powerstroke econoline E-350 cargo van
1999 7.3L superduty F-350 crew cab,lb
2003 6.0L powerstroke F-250 crew cab,sb FX4
2006 6.0L powerstroke F-250 crew cab,lb
1992 chevrolet caprice classic (305 cid
1998 mercury grand marquis LS
michael8840 is offline
post #3 of 23 (permalink) Old 05-26-2010, 06:36 PM Thread Starter
you could have lied to me to make me feel better.
post #4 of 23 (permalink) Old 05-26-2010, 07:00 PM
post #5 of 23 (permalink) Old 05-26-2010, 07:02 PM Thread Starter
I figured that is how my marriage works so why not here?
post #6 of 23 (permalink) Old 05-26-2010, 07:09 PM
plainredtruck's Avatar
Images: 11
Cause we ain't married to you and don't wanna be
Wish you well.
You could, maybe, jack the motor up but I don't know if that will get it out of the way enough to drill your holes.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #7 of 23 (permalink) Old 05-26-2010, 07:21 PM Thread Starter
As deep as the oil pan is I doubt it. I guess I will have to find a way to drill a hole in a cramped space.
post #8 of 23 (permalink) Old 05-26-2010, 09:54 PM
Do you not have to pull the Cab to take out the motor? I would be looking at getting the holes cut with a plasma cutter. Just a thought!
Johnp3 is offline
post #9 of 23 (permalink) Old 05-26-2010, 10:44 PM Thread Starter
Not on the older body style. I do not have a plasma cutter or access to one.
post #10 of 23 (permalink) Old 05-27-2010, 12:02 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
nope engine has to come out, the oil pickup is to long to even jack up the engine enough to get it out.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
engine pull Diesel Dave 04 1994-2003 7.3L Power Stroke 5 05-17-2010 04:37 PM
Pulling engine on 01 2500 4x4 6pd dieselguyoftx 5.9L Cummins (1998.5-2002) 5 05-04-2010 03:32 AM
Pulling the engine?? GOFASORGOBROK 2003-2007 6.0L Power Stroke 11 12-27-2007 02:37 PM
Pulling the Engine out Hitechredneck 1994-2003 7.3L Power Stroke 6 09-19-2007 11:40 PM
Sled Pulling Engine Any Thoughts? strokedout_07 1994-2003 7.3L Power Stroke 35 06-21-2007 06:41 AM
