Exhaust + idling.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NorwegianFord, this thread has received 4 replies and been viewed 1338 times.
post #1 of 5 (permalink) Old 05-28-2010, 12:14 PM Thread Starter
Exhaust + idling..
Hi!
F-250, 7.3, 2002
Need some help, haven't really worked on/touched this truck before, I'm kind of new to the diesel engine..
Having two "problems",
First, when starting up and standing idling, it revs up to a higher "rev" after a little while, and stays there until I press the brake..
Second, when driving, it has a wheezing sound from the exhaust/the back until the engine gets warm..
Why, and what could I do to fix it? I don't have any problems with working on cars, I'm just new and a little unsure about this diesel truck this far.. I am so thankful for any help and suggestions!
Rik
NorwegianFord is offline
post #2 of 5 (permalink) Old 05-28-2010, 10:39 PM
blageurt's Avatar
The wheezing is normal ..it is the EBPV operating as it should. It is a device theat restricts the exhaust post Turbo in order to warm the engine faster. If it is working all is good. When they stick closed and start causing problems then you need to unplug the wires at the Turbo pedestal effectively disabeling it. Worst case scenario is removing it altogether. It is refered to as 'gutting the EBPV"
95 E350 Cargo , BB shim
DP flashed 60 Tow PCM , B&M Aluminium Pan , Transgo Shift Kit , Autometer Triple Pod avec Guages , Cat sleeps with the fishes, Dana 70 FF 3:55 , Timbrens SES Kit
Stage I injectors / IDM mod coming soon
blageurt is offline
The Following User Says Thank You to blageurt For this addition to TDG:
NorwegianFord (05-29-2010)
post #3 of 5 (permalink) Old 05-29-2010, 01:44 AM
balz out's Avatar
truck is operating just fine... good luck with it
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
The Following User Says Thank You to balz out For this addition to TDG:
post #4 of 5 (permalink) Old 05-29-2010, 04:08 AM
Wherever you are, it's still cool enough weather to make your truck go into cold weather operation.
High idle and the exhaust noise are normal. As mentioned, the exhaust wheezing is the EBPV (Exhaust BackPressure Valve). This is a butterfly valve located just before the downpipe. It closes off the exhaust to provide an artificial load on the engine, which helps to warm up the engine a little faster in cold weather.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
post #5 of 5 (permalink) Old 05-29-2010, 12:13 PM Thread Starter
Thanks guys! A lot of new things for me to learn..
idling enging pawsranch3 Duramax 2001-2004 (LB7) 7 12-24-2007 05:48 AM
Extended Idling at low RPM Michael 1994-2003 7.3L Power Stroke 10 09-03-2007 04:30 AM
Weird Idling Notorious6.0 2003-2007 6.0L Power Stroke 1 04-09-2007 09:02 PM
03 F-250 Rough Idling silvervic99stang 2003-2007 6.0 Tuner Forum 11 03-07-2007 11:11 AM
Idling ? rocweiller 2003-2007 6.0L Power Stroke 25 09-27-2006 04:20 AM
