Truck loses power while driving. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdieselpower, this thread has received 19 replies and been viewed 15097 times.
post #1 of 20 (permalink) Old 05-30-2010, 07:08 PM Thread Starter
Send a message via AIM to bigdieselpower Send a message via MSN to bigdieselpower Send a message via Yahoo to bigdieselpower
My buddy has a 1997 F350 7.3L when he is driving down the road the truck loses power while about 35-50mph, when it does it the wait to start light comes on, and you have to let off the throttle completely and get back on it and its fine for abit. The ABS light also cames on once and again, when it does that the truck lunges at a stop and the RPM's go up to 1500RPM, and yougotta trow it in Neutral or you'll run over the *****s in front of you. I hooked my chip up to it and it read Cam sensor so i swapped it out and its still doing it. Any Help on this would be greatly appreciated, this is his daily driver. THANKS!!!
1995 Ford F250 7.3L Powerstroke. Edge Evolution programmer, 4" bully dog turbo back strait pipe exhaust, cold air kit, 4 corner strobe, LED lightbar,35" Mud Terrains, 5th wheel, Panasonic Toughbook mounted on a laptop mount with Garmin Mobile PC.
bigdieselpower is offline
post #2 of 20 (permalink) Old 05-31-2010, 02:42 AM
Any codes?
burningoil is offline
post #3 of 20 (permalink) Old 05-31-2010, 03:37 AM Thread Starter
At first i got a Cam position sensor code, and cleared it, that hasnt come back yet that i know of.
post #4 of 20 (permalink) Old 05-31-2010, 04:36 AM
********* and Mafia #90
Bcarriveau's Avatar
To loose power you need to loose fuel.. change fuel filters. Don't get the cheap ones..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #5 of 20 (permalink) Old 05-31-2010, 01:33 PM
How is the engine oil? These need to be full of good oil. I have seen it before, the owner said it was and all it needed to run rite was a oil change.
post #6 of 20 (permalink) Old 06-01-2010, 02:03 PM
Bcarriveau's Avatar
I dont know much about the 7.3 but could this be a sign of a bad HPOP?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 20 (permalink) Old 06-01-2010, 02:37 PM
plainredtruck's Avatar
Images: 11
I know you don't have any other codes, but check the TPS - Throttle Position Sensor
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #8 of 20 (permalink) Old 06-01-2010, 09:55 PM
TwinStacks
SmknDzl's Avatar
I had an issue of not getting any throttle response here and there but idled fine and turned out to be the speed control sensor in the rear. check the ring gear and/or sensor and wires to it.
good luck and hope you get it figured out soon.
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #9 of 20 (permalink) Old 06-02-2010, 02:35 AM
Images: 11
I've seen the VSS throw the ABS light and knock out the speedo, but never cause the truck to stumble.
Not sayin' it can't happen, just that I've never seen it or heard of it.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #10 of 20 (permalink) Old 06-02-2010, 03:54 AM
Inside the sending unit in the fuel tank there are two plastic screens/filters. Those may be stopped up too
bigdaddy60 is offline
6.9 loses power, then it's ok, then loses power islander16 7.3L and 6.9 IDI (Pre 1994) 1 02-26-2010 10:30 AM
Taho loses power and blows black smoke firecop 6.5L Diesel Engine 5 03-23-2008 01:04 AM
no power when first start driving teamroper24 1994-2003 7.3L Power Stroke 9 11-28-2007 03:45 AM
truck boggs down and loses power at low rpm ford_truck_1976 1994-2003 7.3L Power Stroke 7 01-17-2007 03:23 AM
7.3 Loses Power on Highway NoWake200 1994-2003 7.3L Power Stroke 6 09-13-2006 03:21 AM
