Replaced my clutch with a South Bend - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97_redstroke, this thread has received 11 replies and been viewed 1846 times.
post #1 of 12 (permalink) Old 06-02-2010, 03:21 PM Thread Starter
97_redstroke's Avatar
I have always had a stiff pedal since I purchased the truck and then the throw out bearing gave up on me so I went ahead and replaced everything with the South Bend Clutch and all I can say is WOW! The new clutch is great the pedal feels like nothing before and the clutch engages and goes way smoother than it ever did before. Here are some pics of the clutch disc, it had one broken spring and a keeper missing on another spring that had been allowing it to ride the flywheel and put a nice groove into it.
ID:	26170   Click image for larger version
ID:	26171   Click image for larger version
'97 F-250 HD ext. cab shortbox, 5" mitre cut stacks, edge evolution programmer, DIY intake.
97_redstroke is offline
post #2 of 12 (permalink) Old 06-02-2010, 05:25 PM
7.3 addict
how many miles on the original clutch, it seems to be common at the 120k- 140k mile mark. mine went @ 130k replaced with a LUK like you said wow what a difference in let off.
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #3 of 12 (permalink) Old 06-02-2010, 09:20 PM
brendonv's Avatar
What was yours doing? Mines hoppy, you can't slip it. It's either on or off. Pedal is so stiff I go through those plastic bushings on the pedal in no time.
Gotta get this done, damnit.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #4 of 12 (permalink) Old 06-03-2010, 03:07 AM
balz out's Avatar
i guess im lucky mine has around 180,000 on it.
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #5 of 12 (permalink) Old 06-03-2010, 12:43 PM Thread Starter
Those symptoms sound very similar to what mine was doing and just make sure and replace with a good one because that clutch only had around 35 or 40k miles but it was a cheap one from advanced or auto zone and it sucked big time. The south bend is a great clutch and you will be nothing but satisfied with it, I highly recommend it.
post #6 of 12 (permalink) Old 06-03-2010, 05:26 PM
7.3 addict
yours had the old style fork it may be bent, i've got 250xxx on my truck now still have the orig. bushing.
"quote from tank"
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #7 of 12 (permalink) Old 06-03-2010, 08:40 PM Thread Starter
Very impressed with south bend customer service as well I emailed to inquire about some stickers since none came with the clutch and he sent me a reply back and said they're in the mail.
post #8 of 12 (permalink) Old 06-03-2010, 09:45 PM
brendonv's Avatar
I've got the updated version sitting in a box on the shelf.
brendonv is offline
post #9 of 12 (permalink) Old 06-04-2010, 09:26 PM
brendonv's Avatar
I just heard today my 99 has a single mass flywheel...that true anybody?
brendonv is offline
post #10 of 12 (permalink) Old 06-05-2010, 03:42 AM
those little plastic ushings suck. mine had an issue with the old clutch, the bushing was wore out and oblonged the hole. i had some bronze bushings whipped up to replace them with. its been 4 years and still is great....
1992 F250 7.3 Powerstroke conversion 6" Skyjacker lift straight piped MBRP 4" exhaust dana 60 swap completed
Canadian Club Member #57
kycott is offline
Upgraded Clutch Fork w/South Bend Clutch??? Stinger23 1994-2003 7.3L Power Stroke 5 09-07-2010 11:50 PM
South Bend Clutch Rusty-Carlton Supporting Vendors Forum 2 09-24-2007 12:40 AM
looking for south bend clutch wistlnwoodchuck Supporting Vendors Forum 3 09-17-2007 10:52 PM
Please Welcome South Bend Clutch Bouncer Site Information 21 03-08-2007 05:06 PM
South Bend CON FE clutch Billysgoat Dodge Performance Forum 3 04-05-2006 02:50 PM
