acts like it ran out of fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by orangeruby84, this thread has received 14 replies and been viewed 5310 times.
post #1 of 15 (permalink) Old 06-04-2010, 04:41 AM Thread Starter
I was driving my truck with no problems until i lost fuel pedal. I could continue with my speed but could not excellerate. This only happened for a short distance since I was just about to pull in to fill up. After filling up the truck would crank but I could not get it to start. After being trailered home I pulled the chip out and tried to start. After 15-20 seconds of cranking it started but acted like a motor that had been run out of gas. Shut of and kept restarting doing the same thing. I put the chip back in for some reason thinking that wasn't the problem and restarted. Took for a ride and when I would shift I got the lugged down rattle at 2 grand. No check engine light while on tuner but stock setting sets the light. Oil is not very old plenty full. Just cleaned ipr. After being run down the road it won't start for a while. Any ideas. I don't have a scan tool but probably should buy one.
orangeruby84 is offline
post #2 of 15 (permalink) Old 06-04-2010, 04:52 PM
Truck pullin' S.O.B.
OffKilter's Avatar
Images: 13
How old is your fuel filter?
1999 F-250 Lariat, Red, Super Cab, Short Box, 6.8L V-10
2003 F-350 XLT Regular Cab Long Box 6.0L 6-speed, tinted windows, push bar, 4inch MBRP exhaust, Edge Juice w/ attatude.
1969 F350 "The Shillelagh" future pulling truck, 428ci, 4-speed, 4:10 gears.
OffKilter is offline
post #3 of 15 (permalink) Old 06-04-2010, 05:04 PM Thread Starter
I just changed it when I was having trouble a couple months ago. Once it runs it will go down the road through the full rpm range but doesn't have the power it used to. With tuner it would puff some decent smoke but barely any now.
post #4 of 15 (permalink) Old 06-04-2010, 07:15 PM Thread Starter
Took the tuner out today and took for a short ride. Still odd starting up and just doesn't feel right driving. Been a while since on stock setting so power loss is hard to feel. After two miles cel light came on and shortly there after it just shut off and won't restart. Going to try cam sensor but don't know what else I can try without scanning it.
post #5 of 15 (permalink) Old 06-04-2010, 09:10 PM Thread Starter
cam sensor made no difference.
post #6 of 15 (permalink) Old 06-04-2010, 09:13 PM
plainredtruck's Avatar
Images: 11
What year is the truck?
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #7 of 15 (permalink) Old 06-04-2010, 09:57 PM Thread Starter
2001. standard shift
post #8 of 15 (permalink) Old 06-04-2010, 11:04 PM
Caterpillar Master Tech.
zone3atl's Avatar
sounds like your fuel pickup tube is sucking air somewhere between the tank and the lift pump.... i have the same problem going on with my 2000 F-250. is your filter housing filling up with fuel when you cycle the key on with the engine off?
zone3atl is offline
post #9 of 15 (permalink) Old 06-04-2010, 11:13 PM Thread Starter
i can't get it to start now at all. why would air kick a check engine light. also as soon as it quit i opened the filter and it was completely full. not trying to shut you down. i'm just thinking its electrical.
post #10 of 15 (permalink) Old 06-05-2010, 01:59 AM
Images: 11
Sounds electrical to me.
Just curious, can you test the Throttle Position Sensor?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 12:38 PM
4X4 Acts Retarded fordfanatic69 2003-2007 6.0L Power Stroke 6 11-05-2007 06:26 PM
truck acts weird when stopping and taking off strictlysmoke 1994-2003 7.3L Power Stroke 2 09-04-2007 07:40 PM
6.5 acts like it is dieing, need your help please jat99 6.5L Diesel Engine 14 11-10-2006 10:31 AM
In cold weather the truck acts up Cummins-Power 1994-2003 7.3L Power Stroke 4 07-12-2005 11:01 PM
