loud "pop" after firing up what is it? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brodiesau, this thread has received 5 replies and been viewed 1362 times.
post #1 of 6 (permalink) Old 06-09-2010, 07:06 AM Thread Starter
I hear a loud popping noise after firing up the 7.3. the noise sounds like its behind the dash and sometimes its quite a shock. anyone know what this is?
Also I have to plug in the block heater overnight and the temp is well above freezing. DOH! any ideas I actually think its injectors but the truck runs good so im ot sure 300k near time for a newer truck and to go back to work after spring breakup. Have a good one and thanx in advance.
Bro.
brodiesau is offline
post #2 of 6 (permalink) Old 06-09-2010, 08:13 PM
1996 StrokerKid's Avatar
Needing to plug in at that temp id check your Glow Plug Relay..
1996 F-350 LB CC 4 in. lift 35 in. BFG AT's Go Rhino Grill Gaurd, Stancor GPR.
"Id rather be stroked than rammed!"
1996 StrokerKid is offline
post #3 of 6 (permalink) Old 06-10-2010, 12:16 AM
TwinStacks
SmknDzl's Avatar
the pop could be fom the vent selector changing when it receives vacuum at start-up
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #4 of 6 (permalink) Old 06-10-2010, 03:33 AM Thread Starter
glow plug relay works and glow plug resistaces are all good but do I really need glow plugs at this temp? I wonder if that pop is anything to worry about?
post #5 of 6 (permalink) Old 06-10-2010, 03:20 PM
The sound happens when you leave your A/C on when starting the truck. It's normal. If you want the sound to go away, turn the A/C selector knob to off before killing the engine, and leave it off until after you start the truck.
Pocket is offline
post #6 of 6 (permalink) Old 06-13-2010, 06:18 PM
Banned
is it right after it fires up or is it right before? I'm wondering if you have an unusually load relay or your relay is up against the dash frame.......
BlackCoyote is offline
Miter Stack Beanies 5" 6" 7" 8" DppPower Supporting Vendors Forum 0 10-12-2009 04:45 PM
2001 F250 Crossover Steering & Adjustable Track Bar w/ 10" high (8" lift+2" shackles) kcrowe 1994-2003 7.3L Power Stroke 0 07-02-2009 07:37 PM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 03:53 PM
Loud "thud" when engaging 4x4 high fastback4 General GM Truck Forum 0 02-22-2007 07:20 AM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 08:00 AM
