Fan drive ratio - Page 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by killerbee, this thread has received 23 replies and been viewed 7283 times.
Closed Thread
post #21 of 24 (permalink) Old 05-31-2007, 03:24 AM
BEER SLAYER
TxC seams to be blowing a bunch of smoke about his fan controller. First it's is controlled off coolant temps now it's not...
Brandon
'04 GMC SLE CC SB 4X4 D/A LB7, S/C IV w/ 1057, EFILIVE, HIGHTECH TURBO, QUAD 215, PREDATOR, AUTOMETER ULTR-LITE IIS, AFE II PG/7, MBRP, MAG-HYTEC TRANS PAN & DIFF COVER, BILSTIENS, CALTRACS, PRE-OEM CAT FUEL FILTER, KB STACK SEAL AND EOC, H2'S W/ 285/70/17 BFG A/T, LINE-X, SD MANIFOLD, SLEEVES, AND PRESSURE BLOCK..........
Turbotug is offline
post #22 of 24 (permalink) Old 05-31-2007, 03:55 AM Thread Starter
BUG JUICER and
Originally Posted by cooksvillewildc
On a different note, for simplicity, could one add a thick piece of rubber to the current fan pully to increase its' diameter to decrease fan speed somewhat - not sure what the difference in diameter is between the LB7 fan pully and our LLY one?
:Thumbup:
Michael
04.5 GMC 2500HD SRW LLY
ECM's FOR SALE
killerbee is offline
post #23 of 24 (permalink) Old 05-31-2007, 06:07 AM
BEER SLAYER
The press fit collar out of some type of metal is probably the best choice. Aluminum would be nice to save weight, but as 4hweelin' noted there are wear problems. A powder coating or even a layer or two of bed liner might do the trick. Line-X claims to be able to spray up to 1/4".
Brandon
Turbotug is offline
post #24 of 24 (permalink) Old 05-31-2007, 06:07 AM
BEER SLAYER
Brandon
Turbotug is offline
Closed Thread
