05 rough idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fishnut, this thread has received 3 replies and been viewed 5930 times.
post #1 of 4 (permalink) Old 09-07-2009, 10:05 PM Thread Starter
Exclamation 05 rough idle
I have an 05' duramax, really rough idle between 1000-2000 rpm, but if you step on the gas it smoothes out. What's up, please help.
fishnut is offline
post #2 of 4 (permalink) Old 10-22-2009, 04:39 AM
SmokeCloud's Avatar
I am not really Familar with Duramax's I don't know if they reference their parts like Ford does with Powerstroke, But I am gonna say check your FICM/IDM, " I am not sure If Duramax References the same name for the Fuel Injection Module. That's why I bolded it Id also check your ICP sensor, IPR, and it could be an injector issue as well.
Are you throwing any codes. Id check your MAP/MAT sensor as well. check your intercooler hoses as well.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #3 of 4 (permalink) Old 10-22-2009, 05:25 AM
Pardue the Traveler
New 0mega's Avatar
Do you have a Check Engine Light? Do you have a tune/programer on it?
Have you checked if your fuel filter is on properly?
Singles Club member #250
New 0mega is offline
post #4 of 4 (permalink) Old 10-25-2009, 05:29 PM
A code check as well as checking balance rates will be the first place to start
Eric Merchant
www.Merchant-Automotive.com
Zeeland, MI
1-866-399-7169
ASE/GM Master Certified
AC Delco Independent Repair Center
Authorized Suncoast dealer/installer
State of Michigan Licensed Repair Facility
dmaxalliTech is offline
Tags
2005, diesel, duramax, idle, rough
Rough Idle Detroit Diesel 5.9L Cummins (2003-2007.5) 4 06-28-2009 02:59 AM
another weird idle ?, rough idle oh3_6oh 2003-2007 6.0L Power Stroke 3 01-09-2008 04:48 AM
Rough Idle SMOKIN' GOAT Duramax 2001-2004 (LB7) 1 02-09-2007 02:47 AM
rough idle fordfanatic69 2003-2007 6.0L Power Stroke 0 07-28-2006 02:15 AM
Rough idle 6.0? QtrHorse 2003-2007 6.0L Power Stroke 7 09-16-2005 02:29 AM
