deleting intake heater grid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chevyboy3672, this thread has received 7 replies and been viewed 7963 times.
post #1 of 8 (permalink) Old 07-28-2010, 09:08 PM Thread Starter
how easy is it to delete the intake heater grid?
chevyboy3672 is offline
post #2 of 8 (permalink) Old 07-29-2010, 07:35 AM
SSpeeDEMONSS's Avatar
easy. either buy a delete so you keep yours in tact or just unbolt and pull everything out.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
chevyboy3672 (07-21-2011)
post #3 of 8 (permalink) Old 07-29-2010, 06:52 PM Thread Starter
thanks ats says that a delete kit wont work with at abs pump on 94-98. Why is that? and will a 01 heater grid work?
post #4 of 8 (permalink) Old 07-29-2010, 08:45 PM
at abs pump? dont listen to ATS!
post #5 of 8 (permalink) Old 07-29-2010, 09:52 PM
BUCK2's Avatar
I just took the whole intake plenum off, it only take about 15 mintues and then remove the grid heater so nothing falls into the engine. Then reinstall everything. Just disconnect the wire that go to the grid heater relays from the battery and you are good to go!
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
The Following User Says Thank You to BUCK2 For this addition to TDG:
post #6 of 8 (permalink) Old 04-08-2011, 02:45 AM
Pappy
MOPSD250's Avatar
What the hell is a at abs pump?!!!!
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #7 of 8 (permalink) Old 04-08-2011, 03:57 PM
You can buy a different spacer, and keep the grid heater, you may want to put it back in some day. Putting blobs of silicone, or what ever, in the intake, does no seem like a good idea to me.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
post #8 of 8 (permalink) Old 04-08-2011, 06:37 PM
BUCK2's Avatar
On the 12 Valves it easy super easy to hook it all back up if you want to.
As i stated earlier remove the intake plenum un bolt the grid heater, remove and put the bolts back on the wholes. Then unhook the battery cable that leads to the relays. Then you are good to go!!
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
Grid heater 9512valve 5.9L Cummins 12 Valve (1994-1998.5) 16 02-12-2009 11:39 PM
Grid Heater Prowler97 5.9L Cummins 12 Valve (1994-1998.5) 8 01-28-2009 11:52 PM
Grid Heater zigzkidz 7.3L and 6.9 IDI (Pre 1994) 5 01-08-2008 11:22 PM
Heater grid 67 vert 5.9L Cummins 12 Valve (1994-1998.5) 6 12-01-2007 02:14 AM
grid heater? 02sprtcumns 5.9L Cummins (1998.5-2002) 13 11-09-2007 08:31 PM
