Injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 10 replies and been viewed 3340 times.
post #1 of 11 (permalink) Old 08-07-2010, 10:55 PM Thread Starter
moviking's Avatar
Injectors
Anyone ever tried these ? the write up sounds good
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 11 (permalink) Old 08-15-2010, 04:59 AM
4play's Avatar
IDK, they might be good but I have seen stock injectors pull better numbers than he claims. 780ft/lbs and no smoke sounds easy to do without buying injectors. Not talking chit but the power claims are not a big deal to me.
"THESE INJECTORS WILL HANDLE UP TO 400HP/ 800 FT-LBS OF TORQUE BEFORE THEY RUN OUT OF CAPACITY. "
4play is offline
post #3 of 11 (permalink) Old 08-15-2010, 11:40 AM
strawboss's Avatar
looks like a good deal on that motor $1100, wish I lived in te-has!!
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #4 of 11 (permalink) Old 08-16-2010, 02:31 AM
just ish it
shortbusdriver's Avatar
I wouldnt pay that price for that small of an injector. I charge $150 less for a 5x12.
97 Dodge 3500 POS edition
92 Chevy Short Bus 6.2
shortbusdriver is offline
post #5 of 11 (permalink) Old 08-16-2010, 11:51 PM Thread Starter
moviking's Avatar
FIrst, thanks for the replys............
O.K. mabey I should have ask first, will my sock fuel sticks supply enough for 400 / 800 numbers ?, I'm just looking for more torque to pull a big 5th wheel, and NOT wanting to bellow smoke (not that it's a bad thing, just not me)
Thinking now of just the 3K gsk and 16 deg timing added to my current set up.
moviking is offline
post #6 of 11 (permalink) Old 08-17-2010, 01:28 AM
SSpeeDEMONSS's Avatar
is yours an auto? i did 380/1000 with 180 injectors and 131 DVs. im pretty sure i could have done 400 with a better clutch and some DVs.
if you are going to go with an aftermarket injector go with SDX.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #7 of 11 (permalink) Old 08-17-2010, 05:04 AM Thread Starter
moviking's Avatar
Yes it's auto, as for the SDX's, I'm guessing you meant their 370's
moviking is offline
post #8 of 11 (permalink) Old 08-17-2010, 04:15 PM
SDX II/5x.012.
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
moviking (08-17-2010)
post #9 of 11 (permalink) Old 09-06-2010, 01:33 PM
Looks like your plan to add a 4K GSK and Valve springs may be the best next Mod. If you add bigger injectors you will increase torque and slip your TC, no sense in making power you can not get to the ground. Next advantage in a 4K is it will let you rev high enough that when the transmission shifts it will fall back into its power band. Get the injectors after you get a good TC.
openrange is offline
The Following User Says Thank You to openrange For this addition to TDG:
moviking (09-06-2010)
post #10 of 11 (permalink) Old 09-06-2010, 06:41 PM
Did you catch the cost of shipping $164.15. Wow I have complete sets of 12V injectors that will fit in the small flat rate boxes.
later is offline
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
injectors firehillbilly 1994-2003 7.3L Power Stroke 8 02-18-2009 03:31 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
370 injectors dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 18 05-25-2007 04:17 AM
3 bad injectors FordRacing200 2008-2010 6.4L Power Stroke 11 05-23-2007 04:41 PM
