With my set up what is next to get 500hp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rewind, this thread has received 3 replies and been viewed 2379 times.
post #1 of 4 (permalink) Old 09-03-2010, 03:49 AM Thread Starter
Hi guys.
I have been reading alot here and finally joined. I respect your knowledge here. I have a 95 12v w/ bhaf /#8 plate forward /pluged waste gate/fule screw adjusted so I have smoke on take off then clears up. I dont want to be a poser. I was wondering what mods are neccessary to get in the 500 hp range. I also have 4" strait pipe from turbo out. any advice or input would be much apprecited.
rewind is offline
post #2 of 4 (permalink) Old 09-03-2010, 06:01 PM
The way I would try to make 500 HP and not break the bank.
60 lb valve springs
O ring the head
head studs
16 degrees of timing (maybe a little more)
Work over the AFC
4K GSK
5X14 injectors
Maybe a rack plug (depends on the type of injection pump)
S300 57/65 SS 14cm
later is offline
post #3 of 4 (permalink) Old 02-16-2011, 08:03 PM
im at 550 hp with my pump pushin 450cc 5x12, .24dv and stock head studs
az black smoke is offline
post #4 of 4 (permalink) Old 02-20-2011, 03:53 AM
550 HP can be done with 5X12's but what else have you done?
later is offline
450 to 500hp chrisf97305 1994-2003 7.3L Power Stroke 12 04-28-2010 03:37 AM
How to reach 500hp 02 d-max. lapplander Duramax 2001-2004 (LB7) 7 04-24-2008 02:03 AM
A route to 500hp JohnNolen 1994-2003 7.3L Power Stroke 23 01-09-2008 01:58 AM
clutch (500hp+) Okie2500 Supporting Vendors Forum 2 07-12-2007 02:22 AM
500hp 3.0L Mercedes! The Eagle Dyno Board 0 05-23-2006 06:45 AM
