Fuel system! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsboy98, this thread has received 5 replies and been viewed 1894 times.
post #1 of 6 (permalink) Old 09-27-2010, 08:11 AM Thread Starter
Fuel system!
Hey can anybody tell me what system is better between Fass??, an Airdog?? I wanna put one of the systems in my dodge, But ive heard both sides of the pros an cons from friends, An i would like someone or everyones input! Please help me out.
Thanks guys!
cumminsboy98 is offline
post #2 of 6 (permalink) Old 09-27-2010, 04:05 PM
SSpeeDEMONSS's Avatar
i like Airdog over FASS. theyre both the same setup.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 6 (permalink) Old 10-09-2010, 04:14 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Here is how i see it. I got a fass in my 24v and a airdog in my 12v. I cant tell no difference between them except the airdog is quiter, and the airdog comes with 3/4'' line and fass comes with 1/2'' line. Fass has great comsumer service, One day i was just curious, i wanted to see on how their comsumer service was. They picked the phone up after the 2nd ring and i made up a story and told them about it and they was nice and pretty about it and helped me thru it. Airdog has the worsest comsumer service (my thoughts) Everytime i called them, they didnt answer the phone. They didnt bother calling back either. And when the pump messed up, they kep on telling me that i was doing something wrong and bascally wouldnt replace the pump. And what made me so mad, they kep on giving me numbers to call for help. Even tho i filled out the warrenty papers for it. So i kep on calling and calling, and after a while i guess they got tired of me calling so they replaced the pump.
Just food for thought.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 6 (permalink) Old 10-09-2010, 06:23 AM
the airdog should have come with -8 which is 1/2". i dont know any kits that come with -12.
ive heard the same but rolls reversed and ive also heard(and seen several local friends) of way more fass problems.
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
97CumminsTurboDiesel (10-09-2010)
post #5 of 6 (permalink) Old 10-11-2010, 04:09 PM
Singles Club #2
smokndiesel7588's Avatar
I bought a FASS 150/150 GPH (pump and filter combo). Been pushing 20 PSI from day one and it hasn't given me any issues for the 2.75 years its been on the truck. I haven't dealt with their customer service at all to let you know how that is.
Greg
smokndiesel7588 is offline
post #6 of 6 (permalink) Old 10-14-2010, 04:23 AM
Or you could build your own using a A1000 aeromotive pump and bypass regulator. And you chose your own brand of fuel filters like a fleet filters. It would be different.
later is offline
IDP fuel system bannon_500 2003-2007 6.0L Power Stroke 32 09-25-2009 10:05 AM
Need help fuel system 97CumminsTurboDiesel 5.9L Cummins 12 Valve (1994-1998.5) 4 04-24-2009 01:45 PM
Djs fuel system Blk350on20s 2003-2007 6.0L Power Stroke 16 04-04-2007 11:56 PM
ATS fuel system jersey250 2003-2007 6.0L Power Stroke 9 10-12-2006 11:05 PM
gdp fuel system HOTTAPPER1 Supporting Vendors Forum 0 09-26-2006 01:46 AM
