timing with stock head gasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chevyboy3672, this thread has received 9 replies and been viewed 2528 times.
post #1 of 10 (permalink) Old 12-30-2010, 12:37 AM Thread Starter
how much timing can i run on a stock headgasket befor it blows. i have 100hp imjectors ,ddp dvs 100gph airdog and just orded a silver bullet 62 wt 4" downpipe and wat do uall recommed
chevyboy3672 is offline
post #2 of 10 (permalink) Old 12-30-2010, 04:38 AM
SSpeeDEMONSS's Avatar
you arent going to be able to run much over stock with that 62 and 100hp injectors. do you have studs at least or stock bolts?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 10 (permalink) Old 12-30-2010, 03:54 PM Thread Starter
stock head blots for now im goin to change it all at once down the road when i have the money
post #4 of 10 (permalink) Old 12-30-2010, 05:07 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I held 45 psi of boost and 15.5* timing for a long time with a stock head, and I was running with a lot more drive pressure than that Silver 62 will give you. I'd say 16* is about the limit.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #5 of 10 (permalink) Old 12-30-2010, 06:08 PM
some arent so lucky.
then again, i did run 20.75* and 40psi with stock HG and stock bolts retorqued and didnt have any problems.
post #6 of 10 (permalink) Old 01-03-2011, 02:00 PM
What turbo, drive pressure makes a difference?
later is offline
post #7 of 10 (permalink) Old 01-29-2011, 03:43 PM
bmoeller's Avatar
Ran 16.25* on my '97. Maxed out at 45psi (PDR HX40 60/16 on stock timing, but the peak dropped to 38psi at 16.25* and dropped the EGTs about 150*.
Last engine configuration before trading it off, was 10 plate and AFC housing full forward, 191DVs, DDP Stage 4 injectors, ATS exhaust manifold, BHAF, HTT Killer B2 64/14. Readjusted the 'gates to 38psi to help the head gasket. Dyno'd 416/892.
Stock gasket and bolts (never retorqued).
"Obama = Hoax and Chains"
bmoeller is offline
post #8 of 10 (permalink) Old 01-29-2011, 04:36 PM
WH1C with 18.5cm housing and a ported 12cm housing with the divider drilled out and the wastegate hole drilled out to like 7/8". i believe the gate was set around 18-20psi.
ticking time bomb.
post #9 of 10 (permalink) Old 01-29-2011, 09:46 PM
bmoeller's Avatar
ticking time bomb.
I usually kept it under 25psi. running around empty. Never did find a hill big enough with a load on to slow it down though, in the 5yrs I ran it that way.
Guess I had a good one.
bmoeller is offline
post #10 of 10 (permalink) Old 01-29-2011, 11:23 PM
almost like 6.0s. some are great for a decent amount of mods, some pop at stock power levels.
timing cover gasket Fast_and_furious 5.9L Cummins 12 Valve (1994-1998.5) 8 05-03-2010 05:38 PM
'98 Dodge 12v Head studs and Head Gasket PhilipR Supporting Vendors Forum 2 10-09-2009 10:20 AM
timing cover gasket MoBe88 5.9L Cummins 12 Valve (1994-1998.5) 2 01-14-2009 03:49 AM
Hypermax Head Studs and Head Gasket HotSauce2138 Supporting Vendors Forum 11 04-28-2008 04:40 PM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 04:36 AM
