cummins bosch pump help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins4bt, this thread has received 1 replies and been viewed 2239 times.
post #1 of 2 (permalink) Old 02-27-2011, 02:03 PM Thread Starter
Hello . I am looking to buy a 4bt cummins . it has a bosch inline type A pump on it # are RSV450 1250AOC 13265 then under that 3990754 0000 . my qeustions is will this pump work for automotive applications ? do i need to change the governor ? any help would be great thanks .
cummins4bt is offline
post #2 of 2 (permalink) Old 03-02-2011, 03:56 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
It has the RSV Ag governor on it, but I'd think you could still drive it on the street
Logan
Do Or Die Garage Experiment
cummins power is offline
Tags
cummins 4bt bosch a pump
Bosch pump rpm ? Mack Doctor Jr. Medium and Heavy Duty 1 08-12-2010 11:31 PM
Looking for an inline Bosch pump Mack Doctor Jr. Medium and Heavy Duty 3 07-21-2010 01:49 AM
Bosch PESMW pump help johndear720 Medium and Heavy Duty 8 03-18-2010 02:24 AM
I need help with Bosch inline pump info. Moulder 5.9L Cummins 12 Valve (1994-1998.5) 3 02-07-2008 01:10 AM
Bosch P pump conversion j41385 5.9L Cummins (Pre 1994) 4 01-26-2006 06:20 PM
