Water/Meth injection ?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 3 replies and been viewed 4532 times.
post #1 of 4 (permalink) Old 04-26-2011, 11:05 PM Thread Starter
moviking's Avatar
Pros / cons, I've read up on them (wondering how much of that info is hype) but wanting to hear from those of you that haved used them.
EGT's climb kinda fast on me, 1300 deg by 3200 rpm, wondering what 4k feels like but don't want to push (hand gernade ) it.
Also any home made w/m inject plans out there ?
As usuall, thanks in advance. Don
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 4 (permalink) Old 05-08-2011, 02:27 PM
It will help cool the engine. Making one is easy you need a
Micro pressure switch and a arming switch,
A lock off solenoid and a flow solenoid
A pump that will maintain 100 psi more than your top boost number.
I used 1/4 in poly pipe to connect it all.
And a spray nozzel that is the size you want.
I mounted the water tank in the bed of the truck.
Meth only if you keep boost below 45 psi.
I am not running all that much boost (55 psi on a good day). So I bought a surflow 12 volt pump that puts up 160 psi not much flow. I connected everthing and check that the pump could maintain 140 psi or more flowing thru the nozzel. I used a old boost elbow for a nozzel but tractor supply has plenty of nozzel for corp spraying.
I mounted the poly tank in the bed of the truck with the pump mounted on top with the lockoff solenoid that way the pump stays on and the line pressured up until later. Next mounted the nozzel in the air horn and mounted the micro pressure switch on the other side of the air horn. Then mounted the flow solenoid to the fender and ran the piping. Now the flow solenoid controls water flow allowing it to start at my preset pressure (25 psi) but only if I turn on the lockoff. Boost pressure drops below 25 psi the flow solenoid shuts off.
I do not use it any more or I would post pictures. Would you be interested in it?
openrange is offline
The Following User Says Thank You to openrange For this addition to TDG:
moviking (05-10-2011)
post #3 of 4 (permalink) Old 05-10-2011, 04:11 AM Thread Starter
moviking's Avatar
Thanks for that info, I'm trying to get up a deal for a used snow system right now, I'll check with you if it falls through and see if you still have it and what you are asking for it.
moviking is offline
post #4 of 4 (permalink) Old 05-13-2011, 02:17 AM
You might check with BeCool they carry all the parts or sell systems.
moviking (05-13-2011)
Water/Meth Injection springer 5.9L Cummins (1998.5-2002) 3 05-10-2010 10:13 PM
Water meth injection p7100 5.9L Cummins 12 Valve (1994-1998.5) 4 09-03-2009 09:22 PM
Water / Meth Injection DiscountPowerParts 2003-2007 6.0L Power Stroke 7 05-22-2006 03:02 AM
Water/meth injection jroderick 5.9L Cummins (2003-2007.5) 6 05-11-2006 08:46 PM
Water/Meth Injection HemiEater 5.9L Cummins (2003-2007.5) 2 06-28-2005 06:44 PM
