400 rwhp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tbroadus_41, this thread has received 6 replies and been viewed 3276 times.
post #1 of 7 (permalink) Old 05-09-2011, 09:19 PM Thread Starter
tbroadus_41's Avatar
400 rwhp
Is it possible to get 400 rwhp w/NO smoke. Im calling bs cause I just dont see it happening. Your always gonna have at least a little at lower rpms.
tbroadus_41 is offline
post #2 of 7 (permalink) Old 12-04-2011, 01:58 PM
With what engine?
later is offline
post #3 of 7 (permalink) Old 12-04-2011, 02:23 PM
ADMIN/MAFIA
neeltburn's Avatar
Engine choice is going to determine that. with a 12v no I don't see it happening, with a 6.7L I see it as very possible.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 7 (permalink) Old 12-04-2011, 11:31 PM
gone fishin!
im putting 400+ to the ground with almost no smoke off idle and a haze at 55psi boost...
its all in the setup.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #5 of 7 (permalink) Old 12-05-2011, 03:08 AM
ADMIN/MAFIA
neeltburn's Avatar
I stand corrected..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 7 (permalink) Old 12-05-2011, 10:04 PM
gone fishin!
no neel..... your still correct!!!!!! most people dont know how to tune a motor..... they just put huge fuel to it and say they have a hole bunch of power........ but all the make is smoke!!!!!!!!!!!!!!!!!!!!!!!!!!!! gives the 12alve a bad name!!!!!!!
i cheat!!!! i use methanol and water to spool a big turbo!!!!
post #7 of 7 (permalink) Old 12-06-2011, 12:01 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
Nitrous would also help to this effect as well Mike, but your still basically doing what the OP asked
My LBZ makes 415hp and all it does it puff a little smoke when I lay hard on the throttle from a stop, hardly smokes any other time
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
400 rwhp tbroadus_41 5.9L Cummins 12 Valve (1994-1998.5) 3 05-13-2011 02:26 AM
700 Rwhp 7.3 #2 bbunting 1994-2003 7.3L Power Stroke 39 03-18-2008 04:06 AM
400 Rwhp powerstroke2003 1994-2003 7.3L Power Stroke 15 11-28-2007 03:15 PM
What do I need to have 650 RWHP?? jay74 Duramax 2006-2007(LBZ & LLY) 7 11-19-2007 01:57 AM
450 rwhp 2tonePSD 1994-2003 7.3L Power Stroke 20 11-18-2007 04:01 PM
