nbs big stick cam - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by chevyboy3672, this thread has received 13 replies and been viewed 3299 times.
post #1 of 14 (permalink) Old 05-23-2011, 06:25 PM Thread Starter
nbs big stick cam
does anyone have info on nbs big stick cam
chevyboy3672 is offline
post #2 of 14 (permalink) Old 05-24-2011, 02:18 AM
Are you thining about changing the cam while fixing the KDP? Trust me the only time I change a cam is when the engine is on the bench. It can be done but if you drop a lifter you will have to pull the oil pan.
How much of a change are you looking for from a cam?
later is offline
The Following User Says Thank You to later For this addition to TDG:
chevyboy3672 (07-30-2011)
post #3 of 14 (permalink) Old 05-24-2011, 01:57 PM Thread Starter
yes im thinking about doin it at the same time as the timing case 181/210 cam
post #4 of 14 (permalink) Old 05-24-2011, 04:24 PM
Are you going with a new cam or a re-grind.
And that seams to be the most popular grind.
openrange is offline
The Following User Says Thank You to openrange For this addition to TDG:
post #5 of 14 (permalink) Old 05-24-2011, 07:56 PM Thread Starter
i was goin to go with a new cam and run 98-02 24 valve tappets
post #6 of 14 (permalink) Old 05-24-2011, 11:54 PM
Are you going to do anything to the head?
post #7 of 14 (permalink) Old 05-25-2011, 12:47 AM Thread Starter
hd valve springs for now im goin to do arp head studs later down the road and firering it
post #8 of 14 (permalink) Old 05-25-2011, 03:17 AM
Fire rings have their place, but for me O-rings are less trouble.
Are you going with BB Chevy springs or something else?
post #9 of 14 (permalink) Old 05-25-2011, 04:40 PM Thread Starter
just hd pacbrake springs
post #10 of 14 (permalink) Old 05-26-2011, 12:51 AM
For just a little more money you can get better springs with the Big block chevy springs and get the spring rate you want.
chevyboy3672 (07-21-2011)
Meet Lug Nut and Dip Stick Lonesome7.3 The Parking Lot 20 10-01-2009 07:11 PM
blown out dip-stick 4cstr 1994-2003 7.3L Power Stroke 25 02-03-2009 02:40 AM
dip stick diesel1986 7.3L and 6.9 IDI (Pre 1994) 1 09-28-2007 02:25 AM
Oil dip stick POWER STROKE 99 1994-2003 7.3L Power Stroke 4 09-24-2007 11:35 PM
6.0 dip stick BobandPat 2003-2007 6.0L Power Stroke 5 11-05-2006 04:16 PM
