project truck found. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drkllr, this thread has received 71 replies and been viewed 9987 times.
post #1 of 72 (permalink) Old 11-30-2011, 02:18 AM Thread Starter
drkllr's Avatar
I found a good one. 96 4x4 5 speed 4 10 gears. I got a few wireing issues to fix. and steering box to put in. truck already has south bend triple disc. input shaft 5th gear fix. (bonus) oh yeah and gear vendors. so once i fix the saftey stuff im thinking heavy hauler/// play toy.. first thoughts confirm kdp. head studs port polish fire ring.5 x12---5x16 set of heavy tow twins... bd/ ats both have nice sets. i like the twin ram on my 97 so prob another twin ram. good intercooler. good three piece exhaust and 4 or 5" turbo back. just first thoughts. motor has 200k on it when i open it i will check the inside if it needs it it will be refreshed. I dont really care about the hp numbers I do care that it tows like a pair of tanks tied together. and i figure ill want to play now and then. egts is allways my first thought i like them to be well under control. I will post pictures soon. I welcome any thoughts ideas suggestions on parts.... head . injectors turbos. well let me have it what yall think
97 3500 kdp fixed, 3gsk, 16.5 timing 10 plate full forward , 4" exhaust goerend full build transmision. industrial injection 90 hp injectors, banks twin ram intake, dpi exhaust, bd superb 57/65 hx 40 downpipe, bhaf
97 international 4700 444e/7.3 one tuner nothing else yet
96 3500 dodge haisley head port and polish street cam 5x13 inj speraco intercooler bd r 700 towing twins mbrp exhaust
drkllr is offline
post #2 of 72 (permalink) Old 11-30-2011, 01:41 PM
BUCK2's Avatar
I would fix the KDP, then pull the head off and get studs and oring the head. Also get it ported and polished while its off.
You may want to run a 62/71/12 over a 475 or 480. 4K gsk and a good set of injectors. Also a Fass or Air Dog
BTW I have a set of 5X16 that I am running now, they run clean. I am stepping down a size. These 5X16 will be for sale shortly. PM me if you are interested and I will let them go fairly cheap.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #3 of 72 (permalink) Old 11-30-2011, 10:38 PM Thread Starter
drkllr's Avatar
im still undecided about o-ring vs fire ring. what little i have learned if you are gonna run more than 60 psi go fire ring. well there is a hump in the road. out of the sets of heavy tow twins i have found on the market so far they run 70-80 psi. i know that is not all the time but still. where do yall fall on the whole oring/fire ring debate.
the kdp i was told it was fixed i just feel better if i look myself.
drkllr is offline
post #4 of 72 (permalink) Old 12-01-2011, 02:19 AM
ADMIN/MAFIA
neeltburn's Avatar
I always heard on a DD/Tow Rig you wanted to O-ring ( Valves) and not Fire-Ring ( Cylinders) because Firerings can leak a bit. Call a good machine shop like Haisley and ask them.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 72 (permalink) Old 12-01-2011, 11:52 PM Thread Starter
drkllr's Avatar
thats a good point i will ask cedar city who they use as a machine shop and get the opinion of both. I want to make sure i build it right the first time. I am a little concerned about the boost and longevity.
drkllr is offline
post #6 of 72 (permalink) Old 12-01-2011, 11:56 PM Thread Starter
drkllr's Avatar
a little off subject.. ok maybe alot off subject I loaded two loads of hay today headed to tx. man i am so jealous i want my dodge to pull like these trucks lol
http://www.youtube.com/watch?v=4wVJz1VUsm4
drkllr is offline
post #7 of 72 (permalink) Old 01-05-2012, 01:55 AM Thread Starter
drkllr's Avatar
ok talked to tuner and the machine shop. they both say with the new radius cut groves that fire rings are the way to go. they got rid of the problems that fire rings had. so at this point check the head port polish fire ring etc. 5x16's I am really leaning to the bd towing twins. tuner will allow me to load the trailer and tune to keep egt's under control. .... ok question cams. from what i have found so far cams with ranges to 4k can really wake up a 12v help lower egts .. insert opionions here... now cast, cast billet, new , regrinds ....insert more opinions... and finally supporting vendors with 12v cams.
drkllr is offline
post #8 of 72 (permalink) Old 05-30-2012, 01:19 AM Thread Starter
drkllr's Avatar
ok im off to a slow start but i have the new head ordered machinework being done will be port and polished fire ringed. the farm has kept me very busy more updates will come later
drkllr is offline
post #9 of 72 (permalink) Old 06-02-2012, 01:48 PM
ADMIN/MAFIA
neeltburn's Avatar
Call and talk to Hamilton Cams. Tell them what want to do to the truck and what you want it to do and see what they can do for you in lines of a cam shaft.
Hamilton Cams
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 72 (permalink) Old 06-02-2012, 08:23 PM Thread Starter
drkllr's Avatar
will do i have been looking at different cams trying to make up my mind
drkllr is offline
New Project Truck SmokinCAT Heavy Duty Rebuilds / Rides 19 09-17-2011 02:56 PM
Looking at a project truck 4x4freak 5.9L Cummins (1998.5-2002) 5 05-13-2009 01:09 AM
Our Project Truck amjperformance General Ford Truck and Excursion 19 12-01-2007 10:04 PM
Found my project truck for 466 swap nevrenufhp Diesel Conversion 17 05-03-2007 01:13 PM
maybe a project truck powerboatr Ford Oasis requests 2 05-08-2006 03:12 PM
