Drive pressure VS. Boost pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hayjayhorses, this thread has received 6 replies and been viewed 5667 times.
post #1 of 7 (permalink) Old 01-28-2012, 05:52 AM Thread Starter
hayjayhorses's Avatar
I put a DP (drive pressure (exhaust back pressure)) gauge on my a while back and noticed the DP was about 10-15% lower then the BP (Boost Pressure). then I have a 60 psi BP gauge and a 100 PSI DP gauge. I though maybe the 100 psi gauge was not accurate.
So today I put a 60 psi DP gauge on and drove my truck around, and at no time could I make the DP go higher then the Boost pressure. At 30 psi of boost pulling A hill the DP was at about 28-29 psi.
Could my turbo be this efficient? I have a s362/12cm with the 2 waste gate ports, 12" of 3.5" to 5' straight back, a 1350 Air filter, 13.2* timing.
I ported out the exhaust housing pretty good on the turbo, the head has a little porting done to it.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #2 of 7 (permalink) Old 02-09-2012, 02:18 AM
CR Toney's Avatar
You can get a positive drive pressure. On the cr dodges it can go really negative at high boost and rpm. My 97 dodge I had would do 33 psi and only hit 1200 on the pyro but that was up hills. Check out your fuel pressure I had to put on new lift pump and overflow valve. Get a Tork technology overflow valve. It is amazing how the truck will run with correct fuel pressure.
'95 T800 N14 13sp DO 4.33 gears
'89 W900B 444 Cummins CPL 1280 18sp 3.55 w/2sp axles 19ft CIM grain/silage box
'03 Dodge 2500 4x4 6sp modded just right
'05 Dodge 3500 4x4 6sp w/ Triple C hydra bed
Smarty Touch Centramatics ATS ex manifolds
'06 IH 4300 DT466 Alison 245HP
Authorized Ekotuning.com dealer
CR Toney is offline
post #3 of 7 (permalink) Old 02-10-2012, 04:25 PM
2wpuller's Avatar
I have the gauges in the dash for BP when I put the motor back in it will be hooked up and will post what it is.
Dale
1975 f250 6.0Perkins,twins,6sp allison.HM.airride,4"ex,Airtilt front clip.
72 chevy 5.9 5sp.
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline
post #4 of 7 (permalink) Old 12-19-2013, 12:00 AM
Fahlin Racing's Avatar
Old thread, but its definitely something that can be tied into head flow! Opened another view of how flow is in a turbocharged engine for me anyhow.
Anyone come up with answer to the problem?
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
Gas & Diesel Motorsports
Heavy Equipment/Truck/Trailer parts Specialist
Zeigler Diesel Perf
Socal Diesel
Fahlin Racing is offline
post #5 of 7 (permalink) Old 01-27-2014, 03:12 AM
I will take a silly wild guess, as back pressure to boost ratio increases flow is reduced.
later is offline
post #6 of 7 (permalink) Old 02-02-2014, 03:01 PM
Yes, increase in pressure usually means we are seeing some sort of flow slowing down. I can't put it into words right now but I have something else still brewing in what options that may be apparent.
Could we size a turbo to the capability of the CSA on the exhaust side and maybe see an efficiency difference? hoping in the positive direction any ways. Of course many many variables in the mix.
Zeigler Diesel Perf
Socal Diesel
post #7 of 7 (permalink) Old 02-02-2014, 05:54 PM
Exhaust back preasure is measured in inches of Mercury on most every OEM spec sheet, anything above 3.2 inches of mercury is above spec.
The preasure is taken after the turbo.
Turbo drive preasure, is less than the boost, it can create because there is a difference in volume of air hot air expands.
Just a thought!
Johnp3 is offline
EP (Drive Pressure) 80 + psi? hotrodstones 2008-2010 6.4L Engine Tuner Forum 16 02-26-2010 05:19 PM
drive pressure kc04 5.9L Cummins 12 Valve (1994-1998.5) 73 07-24-2009 10:26 PM
Making a Drive Pressure setup cummins power Supporting Vendors Forum 4 07-21-2009 10:02 PM
How to keep drive pressure line from plugging cummins power 5.9L Cummins 12 Valve (1994-1998.5) 1 07-10-2009 04:59 AM
Any way to boost Low pressure oil pressure? CSIPSD 1994-2003 7.3L Power Stroke 6 10-10-2006 01:15 AM
