Tourqe Plate - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins0797, this thread has received 3 replies and been viewed 822 times.
post #1 of 4 (permalink) Old 01-23-2007, 04:10 PM Thread Starter
cummins0797's Avatar
Send a message via MSN to cummins0797
Tourqe Plate
When taking the tourqe plate out, do you have to remove the injector lines? Or can you do it around them?
And also when turning the star wheel, what exactly does that do?:shrug:
cummins0797 is offline
post #2 of 4 (permalink) Old 01-23-2007, 04:15 PM
Supporting Vendor
Whose plate are you running? These should help http://www.tstproducts.com/INSRUCT98.pdf
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 4 (permalink) Old 01-23-2007, 04:22 PM Thread Starter
its just a stock truck, i ve been seeing where people slide them forward, why not just take it out....need a little more knowledge on this....aw and thank you that guide will come in handy
post #4 of 4 (permalink) Old 01-23-2007, 04:35 PM
Grnkawi is offline
