Turbo Size? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins0797, this thread has received 11 replies and been viewed 1649 times.
post #1 of 12 (permalink) Old 01-27-2007, 12:59 AM Thread Starter
cummins0797's Avatar
Send a message via MSN to cummins0797
Turbo Size?
What turbo do you all suggest on a 12v with 100hp injectors, tq plate gone, bhaf, and the truck has 3.55's if that matters
cummins0797 is offline
post #2 of 12 (permalink) Old 01-27-2007, 10:29 AM
I would run the version of the SV300 I'm running, 64mm wheel with 12cm exhaust housing. It spools faster than a factory and is capable of 70psi of boost safely, and it also has a 1:1 drive ratio so it's not so hard on head gaskets and such.
Ben Towe is offline
post #3 of 12 (permalink) Old 01-27-2007, 10:43 AM
mrector's Avatar
I liked my super B from BD pretty good,(it is a 56/14) It could boost to 45 psi easily, more if you messed with the w/g (factory set at 40 psi). It kept my egts controllable even with my full cut dv's. Although when you go from a stock charger to any aftermarket charger--be aware that it will not spool at low rpms like your stocker did, I was unhappy will all both my aftermarket turbos until I learned how to drive them. Just stating facts from my experiences.
Mikey
89 w250 project truck
mrector is offline
post #4 of 12 (permalink) Old 01-27-2007, 10:25 PM Thread Starter
yeah i heard a larger turbo has a longer spool delay....how much are we talkin here?
post #5 of 12 (permalink) Old 01-27-2007, 11:03 PM
olbetsy98_12v
Hey man i like the truck. Are you gonna be doin alot of sled pullin or is it just a daily driver? And are you wantin a big single or twins?
98 2500,12V,5 speed,4x4,5" Stacks,airaid intake,#10 Plate,435 injectors,Haisley Firerings,FASS pump,Triple gauges,zoom clutch,Mickey Thompson wheels and baja claws.
07 3500 6.7,6 speed,4x4,afe intake,XRT,5in strait pipe.
olbetsy98_12V is offline
post #6 of 12 (permalink) Old 01-28-2007, 08:24 PM
bmoeller's Avatar
I think the 64 will be too big. I think the 62/12 or 62/14 would be a better match.
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 12 (permalink) Old 01-29-2007, 02:40 AM
I run a PS 64 I know a low rpms it can be laggy but like mrector said once you know how to drive it you can drive around it. But I know a lot of people like the 62 for better driveability.
Trapper is offline
post #8 of 12 (permalink) Old 01-29-2007, 03:19 AM Thread Starter
yeah its just a daily driver...how much is the 62?
post #9 of 12 (permalink) Old 01-29-2007, 10:56 PM
Bouncer
For a daily driver with some mild to semi-agressive HP upgrades a 62/14 is a nice charger. Depending on what brand you go with plan on anywhere from $800 - $1200 for a good used one and $1400+ for a new one.
post #10 of 12 (permalink) Old 01-30-2007, 05:41 PM
Supporting Vendor
70 psi on a single and 1:1 drive ratio?? Have you tested this? I can't imagine that setup staying 1:1 much over 30 psi. :shrug:
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
