Boost elbow and 3k gsk ?'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moparcummin, this thread has received 3 replies and been viewed 1659 times.
post #1 of 4 (permalink) Old 01-31-2007, 02:11 AM Thread Starter
I just bought a adjustable boost elbow and 3k kit, 1st ? is where the heck does the the elbow go? I dont see a line from the afc housing going over to the turbo area. 2nd should I take back the 3k kit and get the 4k? someone said the 96+ trucks come with 60lb springs is that true?
Thanks
moparcummin is offline
post #2 of 4 (permalink) Old 01-31-2007, 02:32 AM
the elbow most likely goes on the compresser side of the turbo next to the tag just look you will see it, the gsk depends on how far you want to take performance in the truck, and no they do not have the 60lb springs
DBogo is offline
post #3 of 4 (permalink) Old 07-08-2009, 06:13 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
i was readin your sin. what did you have to do to turn your afc housin all the way forward?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 4 (permalink) Old 07-08-2009, 11:11 PM
Super Moderator
nevrenufhp's Avatar
Loosen the 4 bolts that hold the AFC on, then slide 'er forward.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
The Following User Says Thank You to nevrenufhp For this addition to TDG:
97CumminsTurboDiesel (07-08-2009)
