Timing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rshort, this thread has received 5 replies and been viewed 880 times.
post #1 of 6 (permalink) Old 02-01-2007, 01:10 AM Thread Starter
Timing
Ok gonna get the fire ring, gasket, and studs put in this weekend. Question I have is, are there any reasons I wouldn't want to take timing up to 20. I don't tow anything, I plug it in if it gets 45 or below. Mainly daily driver and will drag race it and sled pull with it this year hopefully quite a bit. Any thoughts on if it's safe or if I can take it higher or lower just let me know.
Thanks,
Ryan
rshort is offline
post #2 of 6 (permalink) Old 02-01-2007, 10:19 AM
mrector's Avatar
20 sounds about right to me. You could start there and go up a little at a time, to see where it runs the best. No problems that I know of, with the timing advanced it should start easier and egts should be a little lower on top end
I am getting mine O-ringed right now, studs, and marine .010" hg. After the job I am going to start out at 20* and probably end up at around 24*-depending on how it runs.
MIKEY
89 w250 project truck
mrector is offline
post #3 of 6 (permalink) Old 02-18-2007, 01:34 AM
My timing is at 16. What would happen it i bumped it up?
imported_smokindodge12v is offline
post #4 of 6 (permalink) Old 02-18-2007, 02:04 AM
Ok I read about setting the timing Is there a short cut?! This seems to be a very difficult procedure even for a mechanic am I missing something?? The chart stops at 16 degree. Enlighten me please I want to set my timing like yesterday!
dangerous196 is offline
post #5 of 6 (permalink) Old 02-18-2007, 02:25 AM
diesel_ram_man's Avatar
Images: 6
If you still have stock headgasket and bolts, any higher and you will run the risk of blowing your HG. I wouldn't go any higher than 16* until you stud and o-ring it.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #6 of 6 (permalink) Old 02-18-2007, 06:12 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
even at 16* isnt a GARENTEE that the HG will last .. it could give now with stock timing.. or bumped up timing! so it depends on ur truck
Jordan
blackcloudCTD95 is offline
