New Era 435s vs DDP4s. RESULTS! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel_ram_man, this thread has received 10 replies and been viewed 1323 times.
post #1 of 11 (permalink) Old 02-07-2007, 01:09 AM Thread Starter
diesel_ram_man's Avatar
Images: 6
Found on another site, Awesome review just had to post it here too:
All results found with this truck setup:
98 2500 QC SB 12v 5sp
Amsoil Air Filter System, Fluidamper, 5" exhaust, 0 plate, 22*, GSK4, AFC spring, 435 EDM's, ARP studs, O-ringed, HTT 64/14 & 3pc manifold, SBC Con OFE, traction bars
So there has been quite a bit of discussion over which injector is bigger and better. But nobody that I have seen had real life results. So I bought both sets of injectors and am here to tell you. Your welcome...
At idle, 435s would haze steady, wouldnt ever seen to clear up. DDP4s would haze for a minute and then its clear. Hard to tell if the trucks running when I cant see the smoke out the stacks! The DDP4s would also cool down quicker than with the 435s.
At cruising speeds, 70mph. 435s ran about 775 to 800 on the pyro, DDP4s ran about 650 to 700 on the pyro.
At WOT, the DDP4s spool faster and the temps dont build as fast. In fact they seem to level off at about 1500. The 435s would keep going. 0-120 would get me too 1500 on the DDP4s. The level of smoke from the DDP4s is quite a bit less too. It smoked a bit until the turbo lit, but after that, it ran pretty clean. The 435s would leave a pretty good haze. Boost went from 48psi with the 435s to 51psi with teh DDP4s.
Mileage, usually got around 13 to 14 with the 435s. Havent filled up yet with the DDP4s yet, but should be soon.
Dyno, I did 518 on #2 with the 435s and will find out on the DDP4s in March. But the seat of the pants dyno noticed a big difference. Even the girlfriend noticed it too.
All the results are at 1300 ft elevation at below zero temps. Its been dang cold around here. Also I took out the .022 DVs for the testing too. With the DVs and 435s I was running 56 psi and smoked a ton, all the time, whether you were trying to or not. I will put them back in as soon as I get some good mileage numbers. Also will have some good dyno numbers with them in and out too.
So far, I am very impressed with the performance and quality of the DDP4s. Seems to be a great product and money well spent. The 435s are a great budget injector that got me some good power and some smokey fun for the pesky rice and tailgators, but if your looking for that last bit of power or wanting less smoke and better mileage, the DDP4s are the winner here.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #2 of 11 (permalink) Old 02-21-2007, 11:59 PM
good info...
i can't wait till the real #'s are posted when you hit the dyno in march.
also chk the fuel mileage difference and the cost...
:smoke
buckeyestroker is offline
post #3 of 11 (permalink) Old 02-22-2007, 12:01 AM
also now that im thinkin about it where in the hell can you buy the 435's
post #4 of 11 (permalink) Old 02-22-2007, 12:38 AM Thread Starter
Images: 6
Chuck @ New Era Diesel Performance Can hook you up with a set. He makes them in house, and he created the 435, more power than the 370s and run alot smoother because the spray pattern is matched to the piston better.
He is located in Zainesville, Oh. Not sure where in ohio you are. Oh and it's not my truck, I got these results from a guy on another site. The DDP's are about $800 and the 435s are $470.
Can You Keep Up??
post #5 of 11 (permalink) Old 02-22-2007, 12:10 PM
Well any dyno results yet? Almost twice the price for the DDPs so I hope so. Good info!
NickTF is offline
post #6 of 11 (permalink) Old 02-25-2007, 04:10 PM
Hey, someone found my article.... Oh well.
I picked up 1-2 mpg and havent hit the dyno yet. March 24th will be the day...
wildmanben is offline
post #7 of 11 (permalink) Old 02-25-2007, 05:42 PM
i think its time for a road trip to zanesville: im likin what im seeing:Thumbup: this could be bad for the savings acountant:squish
post #8 of 11 (permalink) Old 03-08-2007, 09:01 PM
Dyno results?
NickTF is offline
post #9 of 11 (permalink) Old 03-09-2007, 04:10 AM
im still chkn daily for results also:
post #10 of 11 (permalink) Old 04-05-2007, 02:55 AM
Yeah I broke my truck, it could be a while...
