Delivery valves - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moparcummin, this thread has received 14 replies and been viewed 1671 times.
post #1 of 15 (permalink) Old 04-20-2007, 03:28 AM Thread Starter
Delivery valves
Were can I find myself some 022 laser cut delivery valves? can somone educate me on delivery valves? sizes?
moparcummin is offline
post #2 of 15 (permalink) Old 04-21-2007, 02:29 AM
Delvery valves
The 5 speeds come with 181's next step up is the 191's and after that laser cuts. City Diesel probably has the best price on laser cuts.
97 club cab 8 ft box, 4x4, 10 speed 100 plate, BHAF, gauges, timing @15, water injection (devils own), 4 inch exhaust 5 inch stack, double disk, 33" BFGs, Detroit Tru Trac, HTT 35Hx, 4k gov, 60 lb springs pin tabbed, ATS exhaust manifold, high flow delivery valves, fire rings and studs, no fan (two 16" electircs)
mega-ram is offline
post #3 of 15 (permalink) Old 05-17-2007, 08:46 PM
I just bought some Scheid lasercuts not long ago and like them a LOT!!
they fuel quite a bit more than the 191's i had in my truck.
Lance
oldsmokey97 is offline
post #4 of 15 (permalink) Old 05-17-2007, 08:49 PM
diesel_ram_man's Avatar
Images: 6
There is a difference between .022's and L/C's, I believe.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #5 of 15 (permalink) Old 05-17-2007, 09:11 PM
Bouncer
Get with Mrector on this site and you will pay a lot less than anyone else for them and get a whole lot more.
post #6 of 15 (permalink) Old 05-18-2007, 12:58 AM
soot junkie
I agree with Bouncer. Get up with Mikey. I am waiting on my new smaller ones. I had his hot version, but they were more than I wanted to do with my truck. They are now in my brothers truck and we are waiting on another turbo for his now.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #7 of 15 (permalink) Old 05-18-2007, 08:46 AM
mrector's Avatar
I can hook you up!
Let me know what you want, but be for-warned these can be the demise of trannys and clutches, not to mention turbos........
Mikey
89 w250 project truck
mrector is offline
post #8 of 15 (permalink) Old 05-18-2007, 09:28 PM
are your dv's "full cuts" or what???
Lance
post #9 of 15 (permalink) Old 05-19-2007, 01:47 AM
mrector's Avatar
Lance
Depends on what you want, they can be full cuts if you want, but why would you want to make LESS power?? :smoke
I can do whatever you want to them, but, I cant just "give" away my secrets........:
Mikey
mrector is offline
post #10 of 15 (permalink) Old 05-19-2007, 02:31 AM
Images: 6
Hey Mikey you should think of a name for your dv's. Something that they can be identified by.
Can You Keep Up??
