which turbo?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dangerous196, this thread has received 13 replies and been viewed 2203 times.
post #1 of 14 (permalink) Old 05-10-2007, 02:14 PM Thread Starter
which turbo??
If you had a choice of any cummins turbo to put on your dodge which one would you pick? Also a cat turbo off a C-7 has a 4" outlet looks about the same as a hx35 any thoughts about it? Oh and if there is a great cummins turbo out there hope you have a part #!
dangerous196 is offline
post #2 of 14 (permalink) Old 05-13-2007, 03:30 AM
off a C7 is a schwitzer S300 very good turbo
DBogo is offline
post #3 of 14 (permalink) Old 05-23-2007, 01:13 AM Thread Starter
Any turbo's from cummins that can be mixed or matched to build something better?
post #4 of 14 (permalink) Old 05-23-2007, 01:21 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
You could find a hx40 and mod it. I have even heard of some guys using hx52's with some mods. The S300 would be a good start if you have one already.
Putco light bar
Dieselwrencher is offline
post #5 of 14 (permalink) Old 05-23-2007, 03:07 AM Thread Starter
will that s300 bolt up?
post #6 of 14 (permalink) Old 05-23-2007, 06:37 AM
Change the downpipe and it should. The Htb2 line from HTT are S300 varietants right?
post #7 of 14 (permalink) Old 05-23-2007, 11:02 PM
bmoeller's Avatar
Yes they are. Love mine.
"Obama = Hoax and Chains"
bmoeller is offline
post #8 of 14 (permalink) Old 05-24-2007, 12:30 AM Thread Starter
what should I or could I do with this s300?? like a 16 cm housing or???
post #9 of 14 (permalink) Old 05-24-2007, 04:24 AM
Well, what size compressor does it have. And I think a 16cm housing may be a little big on that turbo, the 12 or 14 should be fine depending on how much fuel you have.
post #10 of 14 (permalink) Old 05-24-2007, 05:47 AM
mrector's Avatar
A 14 on the s300 will do fine. My BD "special" is a s300 based turbo 64/14 housing.
You will need an hx-40 style downpipe for this turbo to work, about a 100 bucks anywhere you look.
Here's a couple of pics: Pay no attention to the FRAM oil filter, as I used it for the after-KDP carnage 100 mile oil change.
Mikey
89 w250 project truck
mrector is offline
