someone explain boost!!?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dangerous196, this thread has received 9 replies and been viewed 1081 times.
post #1 of 10 (permalink) Old 05-21-2007, 12:57 AM Thread Starter
Ok So more is better right?! Wrong?? Give me something out there! A stock hx35 is only good to about 26psi after that it's just pumping HOT air?! Can someone explain how 50 plus boost is good and how does that amount get cool enough to be good? Ok to much just the basics please!! Help:shrug:
dangerous196 is offline
post #2 of 10 (permalink) Old 05-21-2007, 02:33 AM
Super Moderator
John_G's Avatar
NOPE! More is BAD.
What you REALLY want is air FLOW, not boost. Boost is ONLY a measurement of pressure, and doubling the boost does NOT double the flow, in fact it may reduce it if the Charge Air cooler cannot keep up.
Proof? OK.
Take a TD engine, any with a CAC. Increase the pipe diameter, improve the CAC flow (reduce pressure loss) and efficiency. You WILL move more air into the engine, make more power, but have less boost.
More boost also means more heat. You cannot compress air w/o heating it, and the more you compress it the hotter it gets. More heat increases EGTs, so you must REDUCE fuel to keep the EGTs in check. If you moved more air with the same or lower boost, you could INCREASE fuel!
I vote for LIBERTY!
John_G is offline
post #3 of 10 (permalink) Old 05-21-2007, 02:43 AM
diesel_ram_man's Avatar
Images: 6
Originally Posted by John_G
NOPE! More is BAD.
Proof? OK.
Very good info right there, Thanks for that John! :Thumbup:
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 10 (permalink) Old 05-21-2007, 04:23 AM
Right, but sometimes boost is the cheapest easiest way to get more air into the combustion chamber. Like John said, it would be better to get increased air into the combustion chamber other ways, I.E. A cam which will keep the valves open longer allowing more air to enter the combustion chamber, and or cylinder head porting.
Also like John said, compressed air equals more heat. Air flowing through the compressor housing on a turbo creates pressure in that housing and the pressure then creates heat. Thats why you start building more heat with the hx35. If you do something to reduce that pressure, I.E. change the size of the housing or change the compressor wheel itself, you will flow more air at lower pressure in the turbo. This equates to more flow but cooler air. This air backs up at the cylinder head and creates boost, the boost is still based off flow, The same amount of flow creates the same amount of boost. however, since it wasn't compressed and heated in the turbo itself, the result is cooler boost, therefore cooler air in the combustion chamber. Cooler air in the combustion chamber means more power and lower egt's because of a better more complete burn.
However, everything really needs to be paired right. If you just throw a turbo with a bigger comp wheel and housing on a truck with no fuel mods you will greatly suffer down low. It takes more exhaust to turn the larger wheel and get it spinning fast enough to flow air and produce pressure. When you aren't producing pressure, the engine is relying on Vacuum to draw air into the combustion chamber. If your Air Fuel controller is set up to flow lots of fuel at low boost, when your engine is starving for air before your turbo has spooled, it smoothers the flame, too much fuel, and not enough air to burn properly. This leads to smoke, low end heat, and can cause excessive ring wear as well. Also when you smoother the flame down low, it becomes harder for the truck to build RPM, lower and slower RPM building leads to more lag, and it just takes even longer for everything to get to be where you want/need it to be to work properly.
Thats why, with a larger turbo on the truck, I'm not a huge fan of running the AFC loose on a mechanically injected truck, or unplugging the map sensor on something like a 24v. Full fuel with no boost isn't the best thing in the world.
There are a lot of things that go into picking the right turbo(s) for your truck, and fueling and Tuning must be matched accordingly. Its easy to build a truck that puts out decent numbers, but its hard to make a truck that puts out big numbers and still functions well all around. Egt's, spool up, reliability, driving manners and of course the power you want.
Hope this helped a little. Sorry if it was disjointed, please feel free to correct any mistakes that you find or ask if you want a little clarification
post #5 of 10 (permalink) Old 05-21-2007, 04:27 AM
Damn son, thanks even though I didn't even ask the question
ckbed is offline
post #6 of 10 (permalink) Old 06-02-2007, 07:14 AM
No problem, I hope its useful information.
post #7 of 10 (permalink) Old 06-02-2007, 12:22 PM
ok help me out with this. I'm running a hx35 stock fuel plate star wheel forward waste-gate plugged is this going to be harmful to my valves in the long run.:shrug:
96 ccab 3500 4x4 5.9 12valve dually. daily driver. afc forward, star wheel all forward. KDP done!!!:Thumbup:BHAF!! 2cycle additive. next up: #0 plate- injectors, timing and TC some day!!!
R-muck is offline
post #8 of 10 (permalink) Old 06-02-2007, 05:23 PM
Its hard to say what boost you're pushing, but you have nothing to be concerned about. All that sliding the AFC and star wheel is going to do is increase low boost fuel. Without a plate and injectors you don't really have to worry about smoother the flame down low, you don't have that much fuel. Also you aren't even close to being out of the compressors map up top without a plate. That isn't that much pressure on the valves on either side of the equation either, intake or exhaust. If you were running a lot higher boost, and therefore drive pressure, I would start thinking about the exhaust valves.
post #9 of 10 (permalink) Old 06-19-2007, 06:12 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
Now me on the other hand.. with DV's injectors and FP.. and running no W/g I EASILY saw 42 psi.. and that was waisted power.. I was off the compressor map I think the compressor map stops arround 32 psi..
Jordan
blackcloudCTD95 is offline
post #10 of 10 (permalink) Old 06-19-2007, 06:54 AM
Yeah, after 32psi, you just start building hot air, and increasing EGT's. If you have enough fuel to push significantly past 32psi, or essentially enough fuel to spool a bigger turbo, get one.
