plate questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DBogo, this thread has received 14 replies and been viewed 1285 times.
post #1 of 15 (permalink) Old 06-18-2007, 08:54 PM Thread Starter
plate questions
alright i put in my plate yesterday, i like it but i got two questions, first what is the size of the break off screw so i can get a bolt to replace it, i chewed it up pretty good trying to get it off, so i need a bolt to replace that
second question when i get into it i get good smoke, but it will blow out smoke rings is that a bad thing?
DBogo is offline
post #2 of 15 (permalink) Old 06-19-2007, 02:16 AM
hmm smoke ring in a even rythum would mean a injector or cylinder problem maybe a fuel delivery problem?! Take a video would like to hear and see that!
dangerous196 is offline
post #3 of 15 (permalink) Old 06-19-2007, 06:08 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
Actually.. I resued my break off screw.. I took a hack saw blade and cut a groove in the head and I re used it.. and I been in there 3 times.. sine I did the #0 now getting the screws out.. with out dropping the washers is a chore
about hte smoke rings.. hmm thats a tough one..
Jordan
blackcloudCTD95 is offline
post #4 of 15 (permalink) Old 06-19-2007, 10:59 AM Thread Starter
maybe the smoke rings could have something to do with the lopey idle, maybe i have a bad injector?, and does anyone know the size of that bolt, its some metric size. mines all chewed up and i cant get it real tight, so i wanna put a new one in
DBogo is offline
post #5 of 15 (permalink) Old 06-19-2007, 11:51 AM
redneckcummins's Avatar
I dnt know the size of the bolt but take it to a hardware store and try to match up the threads if it isnt chewed up to bad.
FOR SALE 2003 3/4 ton goat, 6spd., 5in stacks, AFE stg 2 intake,
Isspro guages and Smarty
Wrecked 94' 12v. 2wd, regular cab auto.Isspro boost,pyro and trans temp. AFE intake. ground plate, .191DV's, 370's KDP ELIMINATED...... you will be forever missed.
redneckcummins is offline
post #6 of 15 (permalink) Old 06-19-2007, 08:43 PM Thread Starter
i think its something like a M6x1.5 does that sound right
DBogo is offline
post #7 of 15 (permalink) Old 06-19-2007, 11:25 PM
I'm pretty sure thats right. I know its an m6, and 1.5 sounds right, but its been a while since I've done it, so I don't remember. I usually take it in to the hardware store and match it up. I also usually replace all 4 with allen key bolts. You are talking about the tamper proof break off bolt on that holds the AFC housing down right?
Lopey idle and smoke rings isn't a great sign. Are you getting much haze at idle?
post #8 of 15 (permalink) Old 06-20-2007, 01:01 AM
BigDodge's Avatar
it's m6 x1.0 bolt.
96 2500 215 pump,CompR62,DDP3's,suncoast convter,6'lift
96 3500 12v auto,Bullseye CompR62 DDP3's,suncoast converter
95 1500 318 auto "for now"
99 1500 360 auto "for now"
95 1500 Bullseye Powered P-Pumped 24v. [email protected]
BigDodge is offline
post #9 of 15 (permalink) Old 06-20-2007, 11:01 AM Thread Starter
whats the lopey idle and smoke rings a sign off? bad injectors? or worse
DBogo is offline
post #10 of 15 (permalink) Old 06-22-2007, 03:47 AM
stillcrazyinlaw's Avatar
Images: 3
check your timing. bump it up to about 15-16
stillcrazyinlaw is offline
