turbos - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Darvin, this thread has received 2 replies and been viewed 624 times.
post #1 of 3 (permalink) Old 07-19-2007, 04:09 AM Thread Starter
turbos
would a first gen. turbo exhast housing which is a 16 cm bolt on to an hx 35. Is the exhast wheel the same. i was thinking about making an 35-40 hybrid but using the 16 for the exhast side to lower temps
Darvin is offline
post #2 of 3 (permalink) Old 07-19-2007, 04:36 AM
Trouble Maker
1st gen housings are either a 21 cm or an 18.5 cm, depending on the year of truck. But yes, a 21 cm, 18.5 cm, or a 16cm bought from a vendor, will bolt right on.
Just make sure the center section is level and tight into the exhaust housing, or you will trash the turbine wheel.
MKoth is offline
post #3 of 3 (permalink) Old 07-20-2007, 05:43 PM
A non wasted gated housing is shorter than the one you currently have. Your exhaust pipe will move forward 1 1/4". Make sure you have that much room for the pipe to move before you do the swap.
On a 1st gen we have to add the same amount for down pipe to clear the exhaust manifold with a wastegated housing. The 2nd gen used the same exhaust manifold. But I am not sure of the differences in the downpipe.
Philip is offline
