16 cm egts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 8 replies and been viewed 906 times.
post #1 of 9 (permalink) Old 08-05-2007, 11:01 PM Thread Starter
cumminsdiesel's Avatar
16 cm egts
How much will my egts drop when I do the 16 cm housing?
cumminsdiesel is offline
post #2 of 9 (permalink) Old 08-05-2007, 11:24 PM
diesel_ram_man's Avatar
Images: 6
Probably about 300*-500*
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #3 of 9 (permalink) Old 08-05-2007, 11:30 PM
I don't think theny would drop that much. Because all your'e really doing is allowing more exhaust to escape faster. Not really giving it muh more air.
willy91 is offline
post #4 of 9 (permalink) Old 08-09-2007, 10:44 PM Thread Starter
then what would be the purpose of it if it doesnt cool you down?:shrug:
post #5 of 9 (permalink) Old 08-11-2007, 05:12 AM
alittle but it mostly eliminates exhaust restriction with the 12 CM housing. you might see like *100 drop, like willy91 said your not putting more in your just freeing up flow so it isn't restricted and building heat. IMA i would get a whole new turbo.
Ryan
imported_7inchstack is offline
post #6 of 9 (permalink) Old 08-11-2007, 05:13 AM
PM SStockton he nows alot about turbos!
Ryan
post #7 of 9 (permalink) Old 08-11-2007, 05:43 AM
Bouncer
I saw about a 100* reduction in cruise temps and a 20hp/65lbtq gain on the dyno when I went from a 12cm to a 16cm non-wastegated.
post #8 of 9 (permalink) Old 09-17-2007, 05:22 PM
Are all 16 cm turbo's non-wastegated? My wastegate on my '97 needs replaced, and I thought it might be the time to upgrade to the 16 cm.
Tippy is offline
post #9 of 9 (permalink) Old 09-18-2007, 04:46 AM
Yes, that i've seen. But the 12 and 14s are availible in wastegated or not.
Dual K20s is offline
