Turbo Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moonshiner, this thread has received 6 replies and been viewed 809 times.
post #1 of 7 (permalink) Old 08-18-2007, 01:11 AM Thread Starter
Turbo Question
Ok, i got a question for you dodge guys, cause most ford guys couldnt answer me, lol.
I'm thinking about switching over to the H2E kit from Hypermax, and the people i've talked to said as long as the turbo has an H2 Flange on it I can us the H2 kit and put any turbo on it.
I'm trying to build the truck into a street-rod, off-roader, sledpuller (switching tires, baby! lol)
Anyway so there the H2, S300, HX50 that come with the H2 flange, What kinda performance can i expect from the HX50 and S300?
Thanks
moonshiner is offline
post #2 of 7 (permalink) Old 08-18-2007, 02:20 AM
from what i have seen a hx 50 is a good size charger it probly work good on your truck
fwdcummins is offline
post #3 of 7 (permalink) Old 08-18-2007, 04:55 AM
Wow, just wow, stay away from Holset in a mid-frame turbocharger. Unless you want to spool it around 2100RPM and then blow a thrust bearing.
Smokem3 is offline
post #4 of 7 (permalink) Old 09-01-2007, 02:28 AM
The S300 is a great turbo for manny applications, they come a lot of sizes too. Look up HTT they have a turbo that will bolt up to your truck.
Trapper is offline
post #5 of 7 (permalink) Old 09-01-2007, 05:10 PM
Here is a link to HTT for ya. They will answer any questions you have on use.
http://www.htturbo.com/index.htm
cjensen91910 is offline
post #6 of 7 (permalink) Old 09-02-2007, 05:57 AM
You are looking for a T4 foot correct? Most of the larger inlet turbine housings are non wastegated, HTT probably won't have a direct answer for you. What wheel sizes are you looking for?
imported_Smokem is offline
post #7 of 7 (permalink) Old 09-02-2007, 06:07 AM
A better question may be what compressor size are you currently running?
