will it hold? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FF4431, this thread has received 5 replies and been viewed 1129 times.
post #1 of 6 (permalink) Old 09-27-2007, 02:40 AM Thread Starter
will it hold?
I just baught a completely stock truck off of some older guy which, as far as i can tell has never been used to tow anything, no trailer brake or vacant screw holes, very clean hitch and plugs, and no fifth wheel; it has a cap on it for god's sake. It was babied all its life and has 70k original miles on it. if all i do is add 370 injectors and slide the stock plate forward will the clutch hold (assuming other necessary mods like exhaust and BHAF?
thanks, chris
FF4431 is offline
post #2 of 6 (permalink) Old 09-27-2007, 02:44 AM
Cummins Man
Dazedandconfused's Avatar
For a while if you dont thrash on it to hard. I would start saving for a clutch before I did sticks though, that is just me though. No sense in having power you cant use.
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #3 of 6 (permalink) Old 09-27-2007, 05:12 PM
It might hold for a while but once it slips the first time it is down hill in a hurry. I think it would hold but thats no gaurantee
What gear ratio does it have? With 4.10s it should hold, but w/ 3.55s its less likely.
Dual K20s is offline
post #4 of 6 (permalink) Old 09-27-2007, 09:56 PM Thread Starter
yeah it has 4.10s, ill probably let it go until it burns er out.
FF4431 is offline
post #5 of 6 (permalink) Old 09-28-2007, 11:16 AM
Murdawg
Mine started slipping in fifth the other day. Now i only step on it in 1st through fourth and it hasen't slipped since.
92 w250, custom front run you over bumper, 8in lift, 37's, flat bed, BOCH190 injectors, 4in dp, 4in aimed at your window exhaust, BHAF, Gauges, 3200k spring, 16 n/wg housing, pump tweeked, Custom intercooler in the works,
MurdawgCustom is offline
post #6 of 6 (permalink) Old 09-28-2007, 02:52 PM
Bouncer
It will hold until you do something to add more fuel to it. Sliding the stock plate and 370's are not going to kill a stock clutch unless it is in bad shape already. Now when you add a different plate and some DV's, then you will be ready.
