return line - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FF4431, this thread has received 3 replies and been viewed 982 times.
post #1 of 4 (permalink) Old 10-06-2007, 03:10 AM Thread Starter
return line
I was told by an old timer today that I should just clamp down my fuel return line, or find the nut which restricts flow back to the injector pump. he said he had done it before and that it helped him. I understand the conept of increasing back pressure so-as to force more fuel out at the injectors but im not sure sure I trust him.
Any thoughts?
Also, does anyone know the average life span on a set of stock injectors.
thanks Chris
FF4431 is offline
post #2 of 4 (permalink) Old 10-06-2007, 03:27 AM
Bouncer
Are you having problems? What are you trying to accomplish? Stock injectors can run a long time, 300k+ miles.
post #3 of 4 (permalink) Old 10-06-2007, 02:01 PM
NHRDA Race Director
Twisted Shifter's Avatar
Some people will pinch the return line as a test to see if the overflow valve is working correctly. It not going to necessarily give you "more" fuel at the injector. What it does is allow the injection pump to fully fill up if the over flow spring is weak.
Twisted Shifter is offline
post #4 of 4 (permalink) Old 10-06-2007, 09:14 PM Thread Starter
just curious for the most part, I didnt take an overflow into account or anything. Just thought that it might be another cheap way to add a little power, the way he talked it up and all.
for the time being i just want to add a little power because i dont have money for a clutch. I think im pretty much maxed out now as far as i understand it.
thanks
FF4431 is offline
