fuel pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wally5096, this thread has received 2 replies and been viewed 727 times.
post #1 of 3 (permalink) Old 11-27-2007, 07:29 PM Thread Starter
fuel pump
Has anyone put a "race car" style pump on their trucks? If so what all needs to be done? I was told that I would need to change the return line in some fashion and to just bypass the lift pump and not to exceed 50psi. Is this correct? Any help would be great.
Thanks,
Jim
wally5096 is offline
post #2 of 3 (permalink) Old 11-28-2007, 02:15 AM
When you say "race care style" are you referring to something like an aeromotive?
lmills3142 is offline
post #3 of 3 (permalink) Old 11-28-2007, 05:57 AM
You only need to mess w/ the return line if you want to use an adjustable pressure regulator instead of an overflow valve.
You could simply splice the pump into the existing system and bypass the stock pump if you wanted. Or you could run all new lines for a clean look and less potential for leaks.
http://www.competitiondiesel.com/for...sure+regulator
Dual K20s is offline
