more power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stock9512valve, this thread has received 14 replies and been viewed 1449 times.
post #1 of 15 (permalink) Old 11-28-2007, 11:21 PM Thread Starter
more power
Hello, I was reading the forums a month ago and I saw where one of you recommended to take the sleeve out of the fender for more air. I have a knn filter, do you guys mean the short sleeve between the airbox and fender? I have a '95 with a cummins of course. I had just purchased the truck 1 1/2 months ago, it looks like it has a catyletic converter on it. Is it lagal to take off on a diesel truck? I'm also looking for a set of factory late '00-'02 8" aluminum wheels at a really resonable price. I like the looks of them better than my 6.5 chromes.
stock9512valve is offline
post #2 of 15 (permalink) Old 11-29-2007, 01:45 AM
Thats the one. You can drill some holes in the bottom part of the airbox for more flow too.
Dual K20s is offline
post #3 of 15 (permalink) Old 11-29-2007, 03:38 AM
Super Moderator
nevrenufhp's Avatar
It's against federal emissions regulations to remove the cat on a gasser or diesel.
Aside from that, it sounds better, EGT's run cooler, and some guys noticed slightly quicker turbo spoolup when running catless. But legally we cant recommend removing it.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #4 of 15 (permalink) Old 11-29-2007, 03:22 PM
If your worried about it, cut it open and remove the insides then weld it shut and put it back on. Same for the muffler if you live in one of those noise restricted neighborhoods. Just my thoughts on that.
post #5 of 15 (permalink) Old 11-29-2007, 03:42 PM
payne86's Avatar
unless you are from the city then i wouldn't be scared to take it off. Ive been pulled over 3 times for my tint on my truck by highway patrol and they never looked under my truck. Unless you be stupid and try to disturb the piece then i don't no why u would get pulled over. I bought my truck in blair,NE(woodhouse) and it was straight piped, and sold my 89 cummins with a straight pipe.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #6 of 15 (permalink) Old 11-30-2007, 04:27 PM
PhilipR's Avatar
I picked up 2mpg when my kitty fell off.......and the reasons above are good too.
-Phil-
PhilipR is offline
post #7 of 15 (permalink) Old 12-02-2007, 07:27 PM Thread Starter
:thanks:
post #8 of 15 (permalink) Old 12-03-2007, 04:32 AM
If you're looking for more air flow, ditch the K&N, and go with a BHAF. Chunk the cat and muffler. While you're doing the BHAF, chunk the silencer ring too.
carolinarednek is offline
post #9 of 15 (permalink) Old 12-07-2007, 08:09 PM Thread Starter
What does BHAF stand for and does it mount on tube going to turbo and chuck the box? Also what and where is the silencer ring ? Sorry about the questions but I'm new to the diesel scene.
post #10 of 15 (permalink) Old 12-07-2007, 08:11 PM Thread Starter
How many holes and what size?
Thanks Alot !!
