Timing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mudguppy, this thread has received 14 replies and been viewed 2166 times.
post #1 of 15 (permalink) Old 12-17-2007, 09:01 PM Thread Starter
Tebow-in'...
mudguppy's Avatar
Timing
welp, recently spoke w/ the [apparenly] only dieselshop local to me. i mainly called to inquire about bringing it in for getting a timing bump, as this is not something i want to try myself, nor do i have the special tools needed.
so this shop (which has a pretty good name) quoted about $400 to do the timing - they want the pump pulled and put it on the bench vs in the truck. that sound right? why that way?
oh, that's plus $175 to pull the pump off and reinstall if i don't do it. so, timing would be a $600 job.
seriously.
that's a bunch of clams to shell out for a motor that i'm not even sure is healthy (blow-by stories).
thoughts?? anyone local that can help??
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
post #2 of 15 (permalink) Old 12-18-2007, 12:52 AM
laugh Sucker born every second they are just checking! Pump doesn't need to come off. You can do the timing in less than an hour if you know what your doing! Find someone with the tools and supply the food! Or drive out to my place! :Thumbup: :smoke
dangerous196 is offline
post #3 of 15 (permalink) Old 12-18-2007, 02:11 AM
Smokin 5.9's Avatar
Thats funny!!
:smoke
00' Ext. Cab short bed, 5 Speed, AFE, 4" two 5" Miters, Injectors, HRVP44, .93 lines&tubes, Edge Drag, Redline, Autometer Gauges, Southbend DD Clutch, Garrett Turbo w/ Manifold, BD Hose and Clamp Kit, Head Fireringed, Port and Polished, Upgraded Valve Springs, A-1 Head Studs, Haisley Street Grind Cam, Fluidampr, Water/Meth, PSI Fuel System, BD Short Shifter, BD Cool Down Timer, 2" leveling blocks, Voodoo Trac Bars, Road Armor front bumper painted to match, 305/70/16 BFG TA's on 16x10 D C's
97 12v Reg. cab, Auto. AFE, 0 plate, Cut DV's, 4GSK, 4" straight, 16.5*, autometer gauges, billet georend.
Smokin 5.9 is offline
post #4 of 15 (permalink) Old 12-18-2007, 07:41 AM
I've heard of this before actually. You still have to re-time the pump when you reinstall it, so your doing 50 extra steps. For that price and the reassurance of not going to that shop I'd buy the tools and do it myself. Or find someone who will rent you the tools, like this guy
Dual K20s is offline
post #5 of 15 (permalink) Old 12-18-2007, 12:28 PM Thread Starter
Tebow-in'...
mudguppy's Avatar
Originally Posted by Dual K20s
I've heard of this before actually. You still have to re-time the pump when you reinstall it, so your doing 50 extra steps....
yeah, so that's the part i didn't understand. reading the tips and threads on timing, i thought you basically HAD to time it on the motor. i kinda feel like calling them back and asking WTF, Over?? :mafia
i've been asking around to everyone i know that's mechanical. we've got a PSD club here and i'll have to ask those guys to search harder for someone that knows the 12v.
or, worse comes to worse, the rental thing may be the way to go.
why's everyone gotta try to snowball you??? :squish
Travis
mudguppy is offline
post #6 of 15 (permalink) Old 12-18-2007, 02:15 PM
They may want to advance timeing internally on pump which makes things easier if you take apart and change timeing often. But if your gonna stick with one timing dont do it that way.
cumminsram is offline
post #7 of 15 (permalink) Old 12-18-2007, 05:51 PM
soot junkie
I have timed several with the pump on the truck. I have had no problems except with the 95 model trucks, some reason they will start to bust up around 2600rpms. I live just east of Charlotte if you are interested.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #8 of 15 (permalink) Old 12-18-2007, 07:31 PM Thread Starter
Tebow-in'...
mudguppy's Avatar
i hear it's about 2 hrs to get to east side of charlotte from here. thanx - i'll keep that in mind!! :Thumbup:
yeah, ideally i just wanted to pay someone for their time but can't seem to find anyone local.
or, if i'm looking at spending a few bux, maybe i should just get the tools and do it myself.
someone on another site mentioned that they bought the tools for like $120. i can't find anything that cheap. anyone got a line on the tools required?? best i can find is $236 from snapon. anyone else?
Travis
mudguppy is offline
post #9 of 15 (permalink) Old 12-19-2007, 01:11 AM
Send a message via Yahoo to ash_flat_diesel
I bought my set from Miller. I will let you borrow them, just like Oreillys, send me the money + freight, when you return the tools Ill return the money.
ash_flat_diesel is offline
post #10 of 15 (permalink) Old 12-19-2007, 01:16 PM Thread Starter
Tebow-in'...
mudguppy's Avatar
thanks, ash' - that sounds like a possibility. :Thumbup:
i'm in no real rush, i'll get up w/ you after the holidays.
Travis
mudguppy is offline
